Need Help Installing Ignition Cylinder
Old Apr 6, 2011 | 08:07 PM
Flat 'n Fat's Avatar
Flat 'n Fat
I removed the lock cylinder on my '79 F-150 with no problems. Now I can't seem to line up the new cylinder to make it go back in. Haynes says "insert the key and turn it to the accessory position. Push the barrel and key into the switch assembly until it is fully seated and then turn the key to the lock position." It's not going that easy for me. The cylinder seems to be offset and won't fully seat. There must be some trick. Any help would be appreciated.
Old Apr 6, 2011 | 08:36 PM
shookdaddy's Avatar
shookdaddy
hey man i had the same problem there is a small hole n the face by the key insert a paper clip n it will turn the rest of the way to get it in the hole so dont feel bad i felt like a idiot when i figured out what i was doin wrong
Old Apr 6, 2011 | 09:09 PM
Flat 'n Fat
I used the wire in the hole to remove the cylinder, but it seems to have no effect in replacing the cylinder and the manuals say nothing about it for re-installation. There are two spring clips in the bottom of the switch socket that seem to be giving me fits. I'm also unsure of which slot in the switch socket to line up with the ridge on the top of the cylinder. In the "lock" position, the key should be straight up and down with the "pin hole" on top.
Old Apr 6, 2011 | 10:24 PM
shookdaddy's Avatar
shookdaddy
Yea I thought the same thing but I had to use the paper clip on mine to get it bk together I had ordered one from lmc had the problem so I went to advance auot parts n got another on n. After an hour of cussing I figured out what I was doin wrong if u look just under the silver peice the key goes through there's a pin that has to line up with that lil hole to get everything look at it real good I hope this helps man if I had known this would have helped me a lot lol
75_92_95
1978 - 1996 Big Bronco
Aug 19, 2016 10:18 PM
nopeda
Aerostar
Aug 2, 2016 09:49 AM
DoofusOfTheDay
Aug 17, 2014 05:35 AM
Tewkman
1997 - 2003 F150
Nov 23, 2013 09:34 PM
sambog
Feb 20, 2005 01:44 PM
