96 7.3l e4od intermittent reverse lights
Old Oct 26, 2012 | 11:13 AM
Armalite's Avatar
Armalite
I notice that my reverse lights don't like to come on most of the ttime. I would have to keep wiggling the shifter and move around the gear range to get them to come on. This all started happening after I got the transfer rebuilt and he replaced the mlps sensor. linkage and all seem to be tight with no play. any suggestions?
Old Oct 26, 2012 | 02:34 PM
Franklin2's Avatar
Franklin2
Here's the switch.
AutoZone.com Repair Guide Image. 3: Removing the Manual Lever Position (MLP) sensor
You have to adjust it. Here's another picture;
AutoZone.com Repair Guide Image. 4: Adjusting the MLP sensor
Here's the procedure;
Park is the last detent when the manual control lever is full forward. Return 2 detents toward the output shaft for Neutral.
1.Position the manual control lever in Neutral .
2.Insert Gear Position Sensor Adjuster tool T93P-700 10-A or equivalent, into the slots.
3.Align all 3 slots on the MLP sensor with 3 tabs on the tool.
4.Tighten the attaching screws to 80-100 inch lbs. (9-11 Nm).
fordfan66
Oct 10, 2025 09:36 PM
natestang
Nov 1, 2017 07:52 PM
D Ray
Aug 10, 2010 09:41 PM
EagleDakota
Nov 8, 2006 04:16 PM
WIN1MOR
Sep 3, 2006 07:34 AM
