melted headlight switch
Old Oct 26, 2012 | 06:50 AM
bigugly'82's Avatar
bigugly'82
hi, i have a 93 F-350 with a melted light switch which overheats when i turn my brights on. i was going to take the switch out of my wrecked 91 but its also melted so I'm guessing this is a common problem. the wiring harness connector is also melted so i need to know how/where do i get parts to fix this. thanks in advance.
Old Oct 26, 2012 | 02:39 PM
Franklin2's Avatar
Franklin2
It is a common problem, and any local parts store will be glad to sell you a new switch and a new connector with short pigtail wires coming out of it that you have to splice in. If the demand is there, they will make it and sell it.
They will also sell you a
new gas tank
new frame brackets for the rear springs
new parking brake cables
new tumbler and keys for the ignition
new linkage piece for inside the column if you have tilt wheel
new front driveshaft
new fangled rear wheel seal when the original keeps leaking
I am sure I have forgotten something
Old Oct 30, 2012 | 07:54 PM
joshofalltrades's Avatar
joshofalltrades
as he said, start with a new switch and plug.
if you want to do more to it, you can search "headlight relay upgrade" and you'll find some info on how to take the real load off of the switch. some people sell kits for it, i've always just done the job with what i had on hand.
Toplait
Sep 11, 2013 11:15 PM
scooterthejake
Jul 24, 2010 02:38 AM
76CamperSpecial
Mar 10, 2010 01:24 PM
93Sunplex
Nov 29, 2008 09:54 AM
knash0727
Sep 13, 2008 06:04 PM
