Motor or Engine?
Old May 20, 2003 | 08:49 AM
V10KLZZ71S's Avatar
V10KLZZ71S
Question Motor or Engine?
I have my theory on this, but i want to see what every one else thinks. Ok, what the difference between an engine and a motor?
Old May 20, 2003 | 09:01 AM
1993F150XL's Avatar
1993F150XL
Motor or Engine?
By definition, an engine is powered by a fuel, such as gasoline or diesel. A motor is electric.
Old May 20, 2003 | 09:06 AM
jbalestri's Avatar
jbalestri
Motor or Engine?
I agree with the previous post.
Typically, I say that a car has an engine. Sometimes when the engine is really built, detailed, I might say "That's quite a motor", but that is rare.
Air Conditioners, power tools, compressors, etc all have motors, never called one of them an engine.
Old May 20, 2003 | 10:54 AM
Purely Ford's Avatar
Purely Ford
Motor or Engine?
Ok I'm going to split hairs. A motor is any device that converts any type of energy into mechanical energy. Engine is the name of a particular kind of motor.
Old May 20, 2003 | 12:51 PM
Rockledge's Avatar
Rockledge
Motor or Engine?
In this day and age maybe we ought to just call it a "powerplant" since none of our trucks would be going anywhere without BOTH electricity and fuel.
Old May 20, 2003 | 01:15 PM
Waxy's Avatar
Waxy
Motor or Engine?
I'm pretty close to 1993F150XL.
My take on it has always been that an engine produces its own power to do work, while a motor uses an external source of power to do work.
Engine - Anything that uses combustion - gasoline, diesel, rocket fuel, etc...
Motor - Anything that uses an external energy source, ie electricity or pressurized fluid, ie. an electric motor or a hydraulic motor.
Waxy
Old May 20, 2003 | 01:40 PM
Purely Ford
Motor or Engine?
Steam engines don't use internal combustion. Yet they are engines. The definition of a motor is not something that uses electricity only to make power and or do work. An engine is defined as a type of motor that converts any form of energy into mechanical energy. The word motor covers all devices that do this. The word engine is just specifying which kind of motor.
All internal combustion engines convert a form of energy into mechanical energy and do work. This means they require energy to do what they do just like an electric motor requires the electrical energy to do work. Internal combustion engines require the external power source of the fuel they burn to create mechanical energy.
Old May 20, 2003 | 03:19 PM
dcexplorer's Avatar
dcexplorer
Motor or Engine?
Yes, but ...
NASCAR guys always seem to talk about their "motors" not their engines.
I grew up thinking motor means an electric motor and engine is a gas or diesel engine.
Old May 20, 2003 | 05:34 PM
fatdaddy's Avatar
fatdaddy
Motor or Engine?
not having any kind of college physics\chemistry It looks to me that the difference twixt motor and engine is in the change of state that the fuel has to go thru for an engine which results in 2 separate forms of energy being produced....(1)Heat or the inefficient part...and(2) mechanical motion..the Efficient part. A Motor (electric) simply takes the electrons and thru the process of electomagnetic induction converts them into mechanical energy. There is a generation of some heat but i thimk that is associated with the resistance of the wire...it is obviously the inefficient part of the process. My definition of efficiency is power consumed vs power produced...or EER , energy efficiency ratio. I wish T1 would weigh in on this as this is his area of expertise......fd
Old May 20, 2003 | 07:33 PM
Greywolf's Avatar
Greywolf
Motor or Engine?
Post number two is exactly correct.
In engineering terms - a "MOTOR" is an Electromechanical Device (IE: "Utilising Electromotive Force"), whereas an "Engine" derives it's power from chemical means.
Additionally - This is why the MORTARS of long ago wars were referred to as "Siege Engines"
(Also catapults which used explosives, or burning incendiary loads)
For additional information - use your favorite search engine(?) to find references to:
"PUNKIN' Chunkin' "!!!
Old May 20, 2003 | 07:54 PM
Freight Train's Avatar
Freight Train
Motor or Engine?
I found this to be interesting reading, it goes into the history of the two words.
engine or motor
Old May 20, 2003 | 09:14 PM
dutchtreat's Avatar
dutchtreat
Motor or Engine?
I remember when the electric drill was called a "drill motor" and here I sit using a search engine on a computer.....ohhhh me
Old May 20, 2003 | 10:39 PM
Jimmy Dean's Avatar
Jimmy Dean
Motor or Engine?
Actually, as in the dictionary or any other reliable source, an engine is a motor, but a motor is not nescessarily an engine, yet it does not go into it much further into it. It does say thatan engine turns energy into mechanical motion. a Motor is by definition something that generates or imparts motion: a device that changes eletrical energy to mechanical energy; or a device that produces mechanical power from fuel
Old May 21, 2003 | 09:51 AM
Waxy's Avatar
Waxy
Motor or Engine?
This is a quote from the article that Freight Train posted.
In everyday, non-technical usage the words have much the same meaning. But they have such clearly defined and fixed compounds (except in the rocket case) that they can’t be thought of as entirely interchangeable. The magazine article argues that the difference is that engines contain their own fuel or are part of a highly integrated engine-fuel system, whereas a motor draws on externally supplied energy. That’s the rule given in the Oxford English Dictionary, but on reflection it seems not wholly satisfactory. It doesn’t work for outboard motor or rocket motor for example. And it doesn’t explain why the two words should have been applied in this way.
It basically supports my interpretation (and that of the majority of posts here) of the general meaning of two words. Of course, as with anything, there are exceptions to the rule.
IMHO, the key is that an engine converts the fuel to energy, where as a motor uses supplied energy.
Waxy
Old May 21, 2003 | 10:18 AM
hawk's Avatar
hawk
Motor or Engine?
like an OUTBOARD or INBOARD MOTOR! so much for that theory
