HEY, Long time member, love this stuff, but I have a problem with my 2000 ex. When I turn on my headlights on low beams they will work for about 20 minutes then both will go out, high beams still work at all times. When I turn off lights and turn back on they come back on, but sometimes go out almost immediately and sometimes stay on longer, almost like a bad relay, but according to my manual there is only fuses and they are fine. someone out there must know whats going on ,or am I missing something, I have replaced the headlight switch, still does it. HELP, THANKS.
Just casting stones into the lake, I haven't the slightest clue on this, but I know that there is a relay that shuts everything off after the key is turned off after a set time. The delay relay. This relay is the cause of grief for windows and radio not turning on until a random time after the vehicle has started.
I'm just guessing but is it possible that cuts it out? If you could find a wiring diagram with anything that is connected to the headlight system it might give some clues. That's a really weird symptom hope you can figure it out.
