Brake Line Fitting Leaking
Old Oct 25, 2012 | 07:06 AM
ch-pow's Avatar
ch-pow
help me over here, guys:
leaky brake line fitting
not sure if I should have put the thread here or there, or if I am now spamming doing this. Sorry if true.
Old Oct 25, 2012 | 07:24 AM
housedad's Avatar
housedad
It sounds like a bad double flare at that end of the line, or the fitting is not tight enough.
The flare is called a double flare. It has to mate to a properly machined boss inside the hole. anything wrong will cause a leak, such as dirt in between the flare and boss, a bad flare, or a damaged boss. It doesn't take much dirt to cause problems.
Also, double flare fittings, once crushed into place, cannot be reused anywhere else without a decent chance of a leak.. The parts are basically married for life.
The fact that you stripped the nut is a telling factor. you probably now are not able to get it torqued down enough
to crush the flare. Crushing the double flare is what makes the super tight seal.
MSM0075
27
Nov 11, 2021 10:05 AM
pbeamtn
17
Jan 4, 2018 08:13 AM
ch-pow
Oct 28, 2012 08:16 AM
doosky2k
Dec 13, 2004 07:14 PM
Torque1st
Garage & Workshop
16
Sep 21, 2002 08:35 PM
