2nd opinion please
Old Oct 29, 2012 | 11:53 PM
04badford's Avatar
04badford
Thanks for conferming jim ,have you tryed running for OfficeLOL , back to this real post bamitI forgot CHECK the MAP sensorand tube .
Old Nov 8, 2012 | 07:13 AM
Bigballzz's Avatar
Bigballzz
Update to the original post here,
I checked the map sensor and hose which were both clean but the pipe on the engine side was almost completely filled with black crudd so cleaned that.
Also installed the blue spring upgrade kit. Idle has been great ( better than ever actually) and seems that it took the lack of power / chugging out of it too.
Not sure which one fixed it but it was 1 or the other.
Thanks all.
Old Nov 8, 2012 | 12:27 PM
MC5C's Avatar
MC5C
After you install the spring kit, see if you can find a way to do a cylinder contribution test to find out if any of the injectors have been damaged by low fuel pressure.
Brian
Old Nov 8, 2012 | 01:44 PM
grantpage's Avatar
grantpage
How do you do a "cylinder contribution test" and will that show an injector that is bad or going bad?
Old Nov 8, 2012 | 02:23 PM
MisterCMK's Avatar
MisterCMK
You use Auto Enginuity or other scan tool.
Old Nov 9, 2012 | 12:40 AM
04badford's Avatar
04badford
GREAT to Hear your truck is runnining better so did you pull the ICP and clean also the conectors, for the surge , ? what was the Prob that you found ? REMINDER = if the ICP plug side dripin oil bad sencer, if not wipe clean and plug in , CHECK 90 on wire could be streatch out to cause short, there for replace .
Old Nov 9, 2012 | 01:25 AM
04badford's Avatar
04badford
EGR cooler, my bud , the dreaded, but the not the end I'M on the same road most have the deleate egr , keep it stock . BENNY will be on to let you P<S just keep the fuel clean and add Cetane boost (Diesel Kleene} grey bottle if no freeze , ( WHITE for deg under o anti gel } I ran both and never felt a diff on truck running , makes a diff in freez conditions
Old Nov 9, 2012 | 01:39 AM
04badford's Avatar
04badford
the thread MOM ended with P so Pis and then start with the project. OK. Clean ICP connection if wire 90 fills nub or loose , pig tail is needed. OEM pig Tail will fit two connections
cyclemanb
Jan 22, 2020 07:43 PM
clarkmetalservice
Feb 3, 2018 10:11 PM
dmonell
Oct 11, 2013 06:04 PM
dhag911
Mar 23, 2012 09:33 AM
Reidicus
Nov 24, 2006 11:03 PM
