Best replacement power window motor F150
Hi,
have a 1990 F150 XLT Supercab & both Power Window motors are stressing, much more so in the winter months. So I am going to replace them & was wondering if there was a tremendous dif in quality per brand.
A1 Cardone
AC Delco
ACI
ARC
Cardone
DAP
Dorman
Motocraft
VDO
Any of these I should stay away from?
The New ACI & ACDelco motors on Amazon are less than the remanufactured A1Cardone motors @ Checker/O'Reilly.
Whats' the dif between A1Cardone & Cardone?
thank you
______________________
89 Bronco XLT 302 EFI
90 F150 XLT Lariat Supercab 302 EFI
A1 Cardone
AC Delco
ACI
ARC
Cardone
DAP
Dorman
Motocraft
VDO
thank you
Do you mean the weatherstrip? If so No, but think that is a good idea. When I replaced the motors on the Bronco wished had done the weatherstrip @ the same time. In fact I'm looking @ weatherstrip kits on Bronco Graveyard right now for both the Bronco & F150.
No - but guess I was thinking if going to the trouble of taking door panels off/drilling holes, cleaning & greasing the lifting mechanism that might as well spend $65 on a couple new motors. They are 22 years old. The ACI motors come with a year warranty & for that price think their worth replacing.
Suppose if I was willing to let the F150 have the garage & the Bronco sit out in the cold for a couple days while I learned how to rebuild the motors it might be worth a try.
thanks
Big-Green-1992
Have you taken the old motors apart and cleaned the coils?
thanks
Amazon also has a pair of new Dorman's @ $73 & they have more customer reviews. 4+ star reviews too. Guess the reason had initially shied away from Dorman was the look. ACI / ACDelco more closely resemble the original Ford motor that will be coming out. In fact ACI & AcDelco look just alike. Wonder if the same manufacturer?
ACI / ACDelco both priced about same = $65. ACDelco slightly less. Sounds like either ACDelco or Dorman would be a good choice.
thanks
thanks
I'd suggest reading this thread, it would be a much cheaper option to try and I think it will solve your issue - https://www.ford-trucks.com/forums/1...krewin-up.html
That is a great thread. Guess I'll pull the motors out before investing in new ones. Perhaps the little plastic gears are worn out. Instructions & pictures in Ford Power Window Repair are excellent.
One other question. Is there a specific grease I should use on the lifting mechanism? Used regular old grease from the gun on one of the Bronco doors years ago - still OK as far as I know. But when fixing the tailgate window last year I used Lithium thinking lighter might be better.
thanks
thanks
thanks
thanks
I don't know the actual answer (but I bet who does *cough*Cos*cough*) but I just used the grease I had laying around in my garage - think it was bearing grease.
Got my hands on a Shop Manual which states Lithium Grease is appropriate for Window Mechanism. Actually reads "Lithium Complex Polymer Additive Grease ESB-M1C208-1A".
Think I'll just use the Lithium grease already have on hand.
page 42-01-1
Apply an even coating of Lubricant to all window regulator rollers, shafts & the entire length of roller guides.
Beast12
07-05-2004 10:01 AM
ZombieSlayer
1978 - 1996 Big Bronco
02-10-2004 04:16 PM
