No brake lights
Old Oct 24, 2012 | 05:12 PM
srauner's Avatar
srauner
No brake lights
I discovered today that I have no brake lights on my '02 Excursion. The center brake light works fine, but the two in the taillights don't come on. Stopped and bought new bulbs on the way home and replaced both, but the ones I pulled out were not blown. Checked the fuse - OK. Taillights and turn signals both work fine. Any ideas?
Old Oct 24, 2012 | 05:53 PM
Franklin2's Avatar
Franklin2
Turnsignals are the same filaments and wires going to the rear as the brake lights. So the wiring to the rear and the bulbs/sockets are good.
The third brakelight comes directly off the brake pedal switch, so the fuse and the switch are good.
This leaves the problem area being the steering column and/or the turnsignal switch. Ford calls the turnsignal switch the "multi-function switch". The multifunction switch takes the brake pedal signal, and the flasher signal, and mixes them together depending on whethere you are going straight or want to turn one direction or the other. It has to mix these signals because they use the same filaments for both functions.
Tilt the column up or down and try it. Sometimes a wiring plug gets loose and tilting the column puts strain on the plug. Other than that, I would bet it's the switch.
Old Oct 24, 2012 | 06:17 PM
srauner's Avatar
srauner
Thank you - that was one of the best and most thorough responses I've ever received to a question on here.
Playing with the tilt, I found the brake lights will work with the wheel tilted all the way down, but no where else. At least I won't have people running up my *** before I find time to get it fixed.
Old Oct 30, 2012 | 07:53 PM
joshofalltrades's Avatar
joshofalltrades
if it isn't a loose plug in there, it may be time to replace that wire harness in the steering column.
does somebody in your vehicle tend to put the wheel all the way up as they get in/out, and move it back down for when they drive? i've seen people that do, and that just kills tilt columns and the wiring they contain.
77_f250_custom
May 12, 2015 06:00 PM
graphicjunkie
Electrical Systems/Wiring
13
May 19, 2012 06:01 PM
bawstenbilly
Jan 8, 2011 11:30 PM
noggins71
Jun 11, 2009 09:11 AM
Nov 8, 2001 06:55 AM
