Sponsored by: Real Truck
Blinker Problems
Old Oct 23, 2012 | 05:58 PM
ntponds's Avatar
ntponds
Blinker Problems
I just had a reading truck body installed on my 2012 F350 pickup. I noticed when i got onto the road that the blinker was going really fast instead of the normal pace. The new body has LED lights. Im not sure if that could be the problem. Anyone have any suggestions for me?
Darren
Old Oct 23, 2012 | 06:08 PM
rohde1017's Avatar
rohde1017
I would have thought that the LEDs would be current adjusted to not cause a significant change to the blinker speed. Just because it makes sense though doesn't mean it happened.
My dumb question of the moment, the LEDs flash with the blinker, light up when you hit the brakes, and glow with the running lights active right?
Old Oct 23, 2012 | 06:16 PM
ntponds's Avatar
ntponds
Yes the LEDs flash with the blinker, light up when you hit the brakes, and glow with the running lights
When i put the emergency flashers they flash at the normal rate of speed only when i use the signal does it speed up
Old Oct 23, 2012 | 06:23 PM
rohde1017's Avatar
rohde1017
Well, I'm going to have to say that I have no idea. It will require someone with more experience with LED lights and perhaps the 2012 wiring setup.
Sorry I can't be more helpful, but now it is included that everything is lighting up so it shouldn't be just an unplugged connector in the back.
Old Oct 23, 2012 | 06:24 PM
Yahiko's Avatar
Yahiko
How is is the flash rate compare turn to hazard?
They should be about the same rate. If not you
may want to add some resistance so they do.
Sean
NOTE : It's all based on current draw. LED's are a low current device. You could try to switch to a HD flasher unit and see if that helps.
Old Oct 23, 2012 | 07:17 PM
ntponds's Avatar
ntponds
The hazard runs normal. The signal goes at least 2 or 3 times faster. I am thinking of swapping out the led's and going to regular bulbs
Old Oct 23, 2012 | 07:25 PM
Adventure Rider's Avatar
Adventure Rider
As stated by Yahiko you probably need a load compensator to provide an equivalent load to the circuit and it will blink at the regular rate
This is a common issue when running LED's
38Chevy454
1983 - 2012 Ranger & B-Series
Oct 27, 2016 10:27 AM
pavementpounder96
Mar 30, 2012 09:42 AM
customhay4u
Oct 25, 2010 09:15 PM
83bigbroncoguy
Nov 26, 2007 07:45 AM
sundog
May 25, 2000 04:22 PM
