Can someone tell me the cheapest not proper way to get about a 2-4 inch body drop on a 69 Ranger F-100.
Please do not tell me to put 1500 lbs in the bed.
Why in the world would you want a not proper way to modify a suspension? You are on your own. I will not help anyone butcher a vehicle leaving it unsafe.
Thanks
Dajudge
To Lower the truck the right way you can put to drop beams up front and a flip kit in the rear.
A Body Drop is when you gut the floor out and build a new one up higher in the cab so the body sits lower over the frame. Very Very involved and expensive to do right.
Just an fwi on terms to try and avoid any confusion.
Thanks
Dajudge
Originally Posted by HIO Silver
Cheapest? Cut one coil out of the fronts.. BUT, that will likely throw off the camber and reduce the suspension travel. Good bump stops are a must.
For the rear, a spring hanger flip.
Then, 50-series tires.
from what i saw on my trucks there is only about 2 inch between the I beam and the frame (bump stop) to get the amount of drop the i beams would be on the frame. might as well just take the spring out and weld the i beam to the frame if its going to be hitting it all the time any ways.......
the only way to get that kind of drop is drop beams/spindles, or do a crown vic front end swap.
