engine knock
Old May 19, 2003 | 11:09 PM
old pig's Avatar
old pig
engine knock
my truck has an engine knock when accelerated. What could it be?
Old May 20, 2003 | 08:02 AM
sgreen's Avatar
sgreen
engine knock
Most likely it is a rod knock if it happens while under hard acceleration.
Scott
Old May 20, 2003 | 10:39 AM
William's Avatar
William
engine knock
Welcome Old Pig! Rods will knock all the time, especially under no load (reving the engine). Knock on startup before oil pressure comes up is also common. Knocking under load, like pulling a hill in third gear can be caused by advanced spark timing, low octane fuel or a higher compression ratio. Spark knock is very bad and will destroy your pistons. Try some 93 octane and set your initial advance at 8BTDC. Post Back
RussB
6.7L Power Stroke Diesel
Nov 10, 2014 08:35 PM
lee1964
Apr 2, 2011 06:58 AM
chromeclassicxl
1983 - 2012 Ranger & B-Series
Feb 28, 2009 09:51 PM
cobden
Sep 30, 2003 03:20 PM
firestorm
Aug 19, 2002 05:48 AM
