2002 F250 Project
Old Oct 22, 2012 | 11:18 PM
nickt916's Avatar
nickt916
2002 F250 Project
got her at an insurance auction for $6300. 2002 7.3 with 148k. I have always wanted a diesel and seems like they are selling pretty high if in great shape or they have high 200-250k miles and still want a good penny for the 7.3s. Since ill be keeping it i didnt mind the salvage title as i know ill fix it with love.
I have never owned a disel or anything bigger than a 4 cylinder toyota pick up and a 305 chevy blazer, so this diesel thing is new to me, im just hoping i remember to fill up with diesel LOL
i drove it home from the auction and here is how it sits at the moment. my goal right now is to try and find some white doors and then put it on a frame and start pulling and/or drilling out some supports or panels that need to be replaced.
nickt916's Avatar
nickt916
finally got it on a frame, hopefully it all lines up perfectly. Seems like most of the damage was visual, like door shells, side step, rocker outer shell. didnt go in as much as i thought.
my goal is to upgrade wheels and tires, convert front to a 05-07 and rear tailgate to newer models that say "super duty" i think those are 07 and up, im not sure yet, and im not sure if it will fit right up either , any tips on that?
Old Oct 22, 2012 | 11:30 PM
VegasFordSD's Avatar
VegasFordSD
Sweet project, and welcome to FTE!
The tailgate would be an 08 I believe and it will fit.
Any questions, come here, the people here are great and there is a ton of knowledge floating around here.
Old Oct 23, 2012 | 02:15 AM
kell104's Avatar
kell104
While anything is possible I bet the rattle under the hood will keep reminding you which pump to pull up to. Seems like the problems start when these trucks are loaned to friends without a clue.
Old Oct 23, 2012 | 05:57 AM
nickt916's Avatar
nickt916
The 08+ tailgate, got it, it will look sweet from the rear, the current tailgate reminds me of a F150.
there is a lot i need to learn yes, its a new world to me.
Old Oct 23, 2012 | 07:22 AM
Texas Chain Ring's Avatar
Texas Chain Ring
If it ran and drove fine, frame straight, than that's not a bad deal. A/c, cruise. 4 x 4, and all the regular goodies work? Windows, at least driver's side? Air bags in tact?
Old Oct 23, 2012 | 07:30 AM
nickt916's Avatar
nickt916
drives straight, gotta check 4x4, cruise control and AC works, driver seat motor doesnt work, all windows and locks work etc...
Old Oct 23, 2012 | 07:46 AM
94WhiteF250's Avatar
94WhiteF250
The 08 tail gate will work, you just need to change the drivers side hinge, pretty straight forward just 2 bolts. I am almost positive it is as follows (FORD OEM ROLLER 4L3Z-83430B39-AA)
I got mine on ebay for like 13 bucks, but I cant find it again for you.
Good luck with the truck
Old Oct 23, 2012 | 01:31 PM
PaysonPSD's Avatar
PaysonPSD
Pic of the driver side hinge you need for the 2008 lift assist tailgate.
Be cautios when removing the old hinge torx head bolts. They have some strong thread-lock on them and tht torx head is easy to strip out.
Also you can get a tailgate with or without the built in steps. Both fit.
KelVarnson's Avatar
KelVarnson
I don't imagine the air bags deployed, but you might want to look at that.
Nice low miles.
Old Oct 23, 2012 | 11:46 PM
nickt916's Avatar
nickt916
thanks guys for that info, ill keep an eye out for the tailgate to do an upgrade eventually.
Nice low miles.
it was a side low hit, it shouldnt effect the bags at all or the sensors. it should be all just fine.
Old Oct 23, 2012 | 11:48 PM
nickt916's Avatar
nickt916
guy did a good job pulling out the side, doors installed and all about 99% lines up, a might just leave it for now, and later on adjust the doors tiny bit more to get all the gaps perfect, but for now its great.
i sure hate the turning radius on this thing lol, my work semi truck makes better turns LOL, i wonder if smaller or bigger tires would make a difference at all...
Old Oct 24, 2012 | 01:57 AM
kell104's Avatar
kell104
Looking pretty good. Finish up that paint and good to go. Yeah, these trucks don't turn tight at all so I just park in the back 40 and walk. Figure I need the exercise anyway. I must say I am impressed with the ride quality of mine, for a 3/4 ton truck I think it rides and handles quite well. Probably better than my old 94 1/2 ton. I test drove a 2500 dodge (dare I admit to it) before I bought mine and I was not impressed at all, felt like one of those big old motor homes going down the road swaying all over.
Old Oct 24, 2012 | 07:57 AM
Km1210's Avatar
Km1210
I'm glad you took that truck and fixed it up. Definitely went to a good home. And you got a great deal on it.
Also, thanks for including pics!
Enjoy your truck and wait till you start modding....the fun never ends.
Old Oct 24, 2012 | 08:06 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Nice looking truck! As for the turning radius, it is what it is! Since you drive a semi, you know all about using your mirrors!
