FRx spring choice
Old Oct 25, 2012 | 06:15 AM
SkySkiJason's Avatar
SkySkiJason
Originally Posted by SSSimon
I'm using a 100 micron stainless fuel strainer.
It's great you've also got a good choice of fuel stations and can be choosy!
How many PSD problems have we seen on this forum where the in-tank strainer has blocked up causing loss of power & poor running, with the stealerships having no idea and replacing all and sundry at cost to the owner?
I've seen that senario enough on this forum to know that I want to take a few basic precautions to make sure if or when that happens to my truck I'll have it easily covered. I can live with the extra complications as 'insurance'. I certainly do NOT want to be cleaning a clogged strainer out on the inside my FULL 70 GALLON long-range fuel tank!
Oh DEFINITELY get rid of the in-tank strainer and replace it with something like you have in front of the OE pump!!! But, it doesn't make good sense to use something like a 2mic water-separating filter in front of the OE pump. This pump does not like restriction on the suction-side and many have suffered a premature failure as a result. Adding another pump to compensate for this borders on just plain silly - IMHO...
Old Oct 25, 2012 | 07:45 AM
Snowseeker's Avatar
Snowseeker
Curious how come no one does anything post pump? I know its getting close to the front end and there isn't much room left but then you could eliminate the lift pump.
Old Oct 25, 2012 | 10:56 AM
timmyboy76's Avatar
timmyboy76
Reason i didnt, was A) like you said, no room for one, plus after the pump, its only about a ft of s.s. braided line then it becomes a hardline, and B), you got a fuel bowl filter post pump..
Old Oct 25, 2012 | 12:54 PM
SkySkiJason
Most fuel/water separating filters work better on suction-side of pump. That may be some of the reason OE filter is so expensive...
The fact is, the OE filter does a good job of removing water, contaminants and air. The non-serviceable in-tank strainer was likely designed to survive the warranty period. By partially 'looping' the return, it does reduce strain on the pump and mitigates heating the fuel in the tank to some extent.
Old Oct 25, 2012 | 05:45 PM
Snowseeker's Avatar
Snowseeker
I'll stick with stock.
I do want to drop the tank and do the mods some day though. Haven't had any of the common tank problems yet so I have been putting it off.
Old Oct 26, 2012 | 08:29 AM
SSSimon's Avatar
SSSimon
Cheap pre-pump is good insurance for your stock pump.
Cheaper than stock, & spin on water seperator is cheap insurance if you want to run home-brew or bio-diesel blend.
Old Oct 26, 2012 | 08:32 AM
Snowseeker's Avatar
Snowseeker
Nothing ever happens to the stock fuel pump, no need IMO to try and protect it with more fittings, connections, and components that can cause possible problems themselves.
Old Oct 26, 2012 | 08:51 PM
SkySkiJason
I have not seen a pre-pump cheaper than $40 shipped w/lifetime warranty...
New Fuel Pump Installation Kit Ford Pickup Van 7 3L Diesel E2236 | eBay
My fuel is clean and dry before I put it in the truck.
Old Oct 27, 2012 | 03:36 AM
Tugly's Avatar
Tugly
Do you use a paper towel for that?
Old Oct 27, 2012 | 08:00 AM
SkySkiJason
Only the best!!
I have a lot more control of this with B100 I make and the WVO I process to use in my truck(s) than I do with the diesel I buy at the pumps... Some folks just dump stuff in their truck and hope for the best - they should probably have redundant filters (and a budget for injector/engine rebuild ).
I will say if you have a filter on the suction-side of the pump, a vacuum gauge to monitor it is probably a good idea. With a pre-pump, I guess a pressure/vacuum gauge would be in order.
Old Oct 28, 2012 | 05:47 AM
SSSimon's Avatar
SSSimon
I hadn't thought of a vacuum gauge on the suction side of the pump. That is not a bad idea!
At $40 for a replacement stock pump I can see why you'd just run the standard system (with strainer external to the tank), and just carry the spare pump for insurance
The problem with Bio, as I understand it, is that while it might be dry at delivery, if it remains in your tank for an extended period it can absorb water from the atmosphere, much moreso that mineral diesel oil.
BTW, nearly finished fitting my FRx today. But I dropped one of the head fittings. It fell down the front of the engine, I spent hours seaching for it in vain. Bollocks!
Old Oct 28, 2012 | 08:08 AM
Tugly's Avatar
Tugly
Beware! That link takes you to an ad for a Global Automotive pump with an Airtex part number and the picture of a Bosch pump. I'd dig deep before plunking my money on that one.
I just went through all my gyrations on the best pump for these trucks, with the goal of going another 15 years and 300,000 miles. I couldn't find a better one than the stock pump... but the stocker costs a Buck$Zooka round. Clay has the best deal I could find when I factored price, shipping, and time to my location.
Old Oct 28, 2012 | 08:40 AM
  #28
SkySkiJason
I know a couple people running them now - for VO systems - but that don't mean they're gonna hold up. Fingers crossed...
I've got 5yrs and over 120k miles on the Airtex pump in my VO system.
The beautiful thing about redundant fuel systems is I can always get home on the 'other' fuel!!!
Old Oct 28, 2012 | 09:04 AM
  #29
Tugly's Avatar
Tugly
I'm not saying any of the aforementioned pumps are "bad", I'm just saying that particular ad has conflicting information and I'd be wary.
Mcrafty1
Jan 2, 2016 02:41 PM
brian42
May 13, 2015 11:15 PM
endobear
Apr 28, 2012 09:04 PM
teppler
Feb 28, 2010 09:32 PM
teppler
Feb 19, 2010 11:08 AM
