Bad things man...
Old Aug 30, 2002 | 10:59 PM
MustangGT221's Avatar
MustangGT221
Bad things man...
Old Sep 4, 2002 | 05:16 PM
Attaboy2k2's Avatar
Attaboy2k2
Bad things man...
Hey guys...
Today my truck has decided to test the forums troubleshooting prowess.
Actually the problem started a couple of days ago. After a few minutes of driving, I noticed the tachometer drop. The truck stalled for a second, and restarted. It did that twice.
The next day, it stalled and didn't restart right away, rather, it sputtered and misfired a few times, but once started, it ran fine.
Today after a couple of episodes, and sitting for a while, it won't start at all. It will sputter and misfire, but won't continue to run as before.
So you know, it is a 1988 F150 Lauriat, 5.0 motor, dual tanks,(this problem happened while using either tank).
My guess...fuel pump, filter??
Your help is appreciated!
Old Sep 4, 2002 | 06:24 PM
GammaDriver's Avatar
GammaDriver
Bad things man...
Those two would be my guesses, as well as the FPR.
Still, have someone crank it while you look to make sure you have consistent spark at at least one of the spark plugs. (Pull a plug, or have a spare, plug it into a wire & rest the other end against the head or something - you should see a spark jump).
Old Sep 4, 2002 | 08:23 PM
mickelsons's Avatar
mickelsons
Bad things man...
when it was sputtering what was the tach doing? was it totaly at the bottom or was it moving with the sputters? it could be that you were loosing your ignition and that is why there wouldn't be any power to the tach when it was dieing. just a thought.
Good luck
Old Sep 4, 2002 | 08:29 PM
Attaboy2k2's Avatar
Attaboy2k2
Bad things man...
The tach was responding to the sputtering. It was as if the truck was fighting for fuel.
It was the sputtering that gives my mechanic the feeling that it could be ignition related. He seems to think that the distributor could be the cause....I'm STILL hoping for a clogged fuel filter!
Old Sep 4, 2002 | 09:24 PM
GammaDriver
Bad things man...
[updated:LAST EDITED ON 04-Sep-02 AT 10:25 PM (EST)]I'm confused, I thought you were asking for everyone's time and effort here to work on the truck yourself.
Old Sep 4, 2002 | 10:25 PM
MustangGT221
Bad things man...
I'm going to suggest a fuel pressure test, those are easy to do.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
Old Sep 5, 2002 | 10:46 AM
TallPaul's Avatar
TallPaul
Bad things man...
Sometimes our mechanics need help too (sometimes a lot of help). My front end clunk took me several go arounds both at my mechanic's place and here on FTE. Finally someone posted the solution, which I passed on to my mechanic and he fixed it.
INLINE SIX POWER! '95 F150 XL
300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too!
"Drive a stick young man! There'll be time for automatics when you're old and unable."
Old Sep 5, 2002 | 10:54 AM
Attaboy2k2's Avatar
Attaboy2k2
Bad things man...
The mechanic I speak of is my nephew.
After my truck wouldn't run I needed to remove it from
it's location. When he started talking about ignition possibilities, it was time to let him check it out at the shop.
Oh well...I guess I'll justhave to drive the convertible!!
Old Sep 5, 2002 | 11:57 AM
Nutter's Avatar
Nutter
Bad things man...
I just went through the exact same symptoms.It turned out to be the modual on the backside of distributer.Apperantly it controls spark
and injector sequence. I swapped the mod and pickup in dist out of
my wreck and now it runs like a top.
Hope this helps
Old Sep 5, 2002 | 12:40 PM
Attaboy2k2's Avatar
Attaboy2k2
Bad things man...
The Pickup...that is a part he mentioned as well.
He is convinced that this is going to be the cause.
Thanks.
Old Sep 5, 2002 | 08:12 PM
Attaboy2k2's Avatar
Attaboy2k2
Bad things man...
Well...it's like this.
After many hours of troubleshooting, my mechanic who has a buddy at a local Ford dealer, flatbedded my truck over for a little after hours Ford fun.
They connected my truck to the diagnostic computer and it ran perfect!
That's the good news...the bad news is that I need to replace the computer in the truck.
Actually it being an '88, the board won't cost me too much...probably around $60.00 after my nephews incredible discounting!
Nice to have a mechanic in the family!
More good news is that the tech at the Ford dealer loves these trucks, so I'm told he ran all sorts of diagnosis on all systems!
The word was he was very impressed. All systems reflected a truck with about 30k miles...mine has 125k.
So all's well that ends well...thanks for all the input!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
