Wiring Project Help
Old Oct 23, 2012 | 07:16 PM
Adventure Rider's Avatar
Adventure Rider
Thanks HD for the comparison shot.
When I look at mine and then yours I see where mine should mount
As your wiring harness goes over the frame rail - where does it go to - that could be another area where I can look
Old Oct 23, 2012 | 07:27 PM
Hdslider's Avatar
Hdslider
On the drivers side. Just look where my harness goes over the frame.reach in there .about distance of yor hand.and you will feel a main loom. If the take off is there you will feel it. If so just pull it back over. I didnt ck on passengers side.where take off is.
Old Oct 24, 2012 | 05:00 PM
Adventure Rider
Just checked - I have robbed
So what other options would you suggest to pull a courtesy time out?
Also do you know of where I can get a pin out for the 7 position Trailer connector?
Thanks for your help
Old Oct 24, 2012 | 06:08 PM
Hdslider's Avatar
Hdslider
Adventure. Well buddy we gave it our best. It sucks for sure. Will see what i can come up with.What brand lights are you going to hook up? Are the recon?
Old Oct 24, 2012 | 06:28 PM
Adventure Rider
Yes we did!
The lights are retro solutions amber/white DRL led
If I can't connect the whites no big deal - as I think I got the ambers figured out how I want it to work, but it would be nice!
Old Oct 24, 2012 | 06:36 PM
Hdslider's Avatar
Hdslider
The whites are for only when door is open correct.till it times out.right?
Old Oct 24, 2012 | 07:04 PM
Adventure Rider
Yes - that would be the plan
The lights come on, illuminate the step for a bit to get you in and then off
Old Oct 24, 2012 | 07:22 PM
Hdslider's Avatar
Hdslider
Dome lamp circuit. Frt or rear would work. Pm me your e mail and i have some schematics that may help you.
Old Oct 25, 2012 | 04:08 AM
Adventure Rider
PM sent - thank you!
Old Dec 2, 2012 | 05:06 PM
McFarlandkm's Avatar
McFarlandkm
I believe the pin out for 7/4 plug is actually on the spring loaded cover.
Old Dec 3, 2012 | 07:17 PM
Adventure Rider
You are absolutely correct - thank you
This will be very helpful
Gayle Brewer
2009 - 2014 F150
Jul 1, 2019 06:05 AM
Digmonte
Mar 4, 2018 12:50 PM
tiopet
Apr 12, 2013 02:14 AM
MemOrex
Electrical Systems/Wiring
Jan 13, 2005 08:57 PM
ivanribic
Jan 11, 2004 09:26 PM
