The best degreaser?
Old Oct 22, 2012 | 03:01 PM
Cmedic's Avatar
Cmedic
The best degreaser?
Ok I want to know what is the best/ safe degreaser to use to clean out the valley on my 2000 7.3. It looks like a oil top road between my vc's and there was some oil or diesel down in the valley. I just don't want to put something in there that could jeopardize my rubber hoses and electrical components.
Old Oct 22, 2012 | 03:20 PM
Tugly's Avatar
Tugly
My method: Gobs-o-paper towels to dob out the pools, then Simple Green spraydown, beverage or smoke break, then a good non-pressurized rinse. I'm looking into getting an air-powered vacuum from Harbor Freight to make this easy on the fingies next time.
[LINK]
Old Oct 22, 2012 | 03:33 PM
Cmedic's Avatar
Cmedic
Thank you. Another question do you dilute the simple green spray or use a full strength? As nasty as mine is prob gonna a few good cleanings and a ccv reroute along with a bunch of other stuff to be replaced or rebuilt.
Old Oct 22, 2012 | 03:41 PM
Tugly's Avatar
Tugly
No need to dilute... that stuff's pretty tame.
Old Oct 22, 2012 | 03:53 PM
SARDiverDan's Avatar
SARDiverDan
Just be mindful of where the truck is parked or you will trash the driveway. You might want to park it out in the street if it is that dirty and keep the driveway for your more "routine" cleanings
Old Oct 22, 2012 | 04:00 PM
Cmedic's Avatar
Cmedic
Yes sir I'm going to clean it out by my fence line so maybe I won't have weed eat along it as much
Thanks for the info
Old Oct 22, 2012 | 04:41 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by Cmedic
a ccv reroute
I suggest you clean out the doghouse while you have it off. Quite a bit of oil vapor condensation builds up inside.
Old Oct 22, 2012 | 04:48 PM
Pitcrw6's Avatar
Pitcrw6
I use purple power non diluted.
Old Oct 22, 2012 | 05:07 PM
BadDogKuzz's Avatar
BadDogKuzz
Well I use old school engine degreaser from the parts store. Just make sure you cover the alt and power steer pump cap. It is the only thing that will really cut the old build of grease, oil and dirt. So it isn't something the EPA wants going into the ground. But if the EPA doesn't like it I love it!!!
Also like Robin said clean out your doghouse really good. You'll be surprised how nasty it is. And replace the orings from Bob/ Diesel Orings or Clay/ Riffraff.
Old Oct 22, 2012 | 05:27 PM
Cmedic's Avatar
Cmedic
Will be sure to clean the dog house once I can order ccv reroute kit. Again thanks for the help
Terry SD
Nov 2, 2012 12:51 PM
ToMang07
13
Jun 6, 2011 06:16 PM
slim613
15
May 30, 2011 06:50 PM
petebal
Bio-diesel, Propane & Alternative Diesel Engine Fuels
36
Mar 26, 2007 11:18 PM
