Ive been thinking of getting the clear corner lights off Ebay for my 1999 F350. Does anybody have them or has anyone bought them off Ebay & if so how are they. I dont want to get some chinese POS that isnt sealed very well. Thanks.
Mine clear turn signals, and my 02-04 headlights are both cheap knock offs off of ebay. I have no problems with either ones.
The bottom one is the company I got the turn signals from. The clear I bought are showing up sold, but he may have more.
PIN, thanks for the links & info, Ill check them out. I had a bad experience with cheap lights that leaked, fogged up, and eventually looked like a fish bowl (no joke either).
Mine havent leaked yet. But anytime if I buy things like that on ebay, before I put them on I run a thin bead of silocone around where there stripping supposed to be to be safe. And me personally, I think mine look good.
And the link to the headlight company, I gave them major props on ebay. Most companies there say there complete, but there lights are all the way down to the adjusters and they give you bulbs. I got the Ford ones, then after they got here and I was impressed, I ordered some for my 03 Ram 2500. Both sets were great and complete.
I guess my other post didnt work. So I ordered my clear headlights & corner lights from Rock Auto. For my 1999 they didn't have clear marker lights so I just ordered the ones for a 2002 or 2003......should fit fine right...? Well once I installed them I noticed that the upper point of the signal lights stick out quite a bit where it should mate up to the fender. It's like as if they are both tilted forward & there is no adjustments for these, just the two bottom screws hold them in.
Anyone have the same issue?
Thanks.
there is a hole in fender that a peg goes into near the top of that light find the hole problem solved. probably have to unscrew the bottom first
No it's not that. Peg is aligned & barely engaged because it's tilted forward so much once bolted down. I know the original factory lights stuck out slightly but not nearly that much.
are you locking the top in first before tightening the bottom. is the peg shorter on the new one pics maybe?
Yes I got the peg aligned before tightening it & once it's all bolted up I can push the light assembly back & fully engage the peg in the hole but it just springs forward leaving that big gap. I didn't know if there was a reason why those weren't an option to purchase from rock auto for a 99 but I've seen all these headlights for newer models & also those same types on other peoples 99s so I just figured it wouldn't be an issue.
