1998 E250 5.4L massive trouble!!
Old Oct 22, 2012 | 09:28 AM
ethanrover98's Avatar
ethanrover98
Hello all,
I am having a terrible time with a 1998 E250 with a 5.4L engine. The van is a farm truck for traveling to farmers markets and I am trying to save the owner some money. The truck was running very bad, so I decided to changes the plugs.........
-the plugs were burned up and the gaps were close to .100. Changed all of the plugs and the truck ran a little better, but not much
-then the exhaust fell down and in turn melted the rear O2 sensor wires which in turn blew a 30amp fuse under the hood. Put a new sensor in and jury rigged the exhaust back up.
-after the fuse change I had no fuel pressure. Dropped the tank and put a new fuel pump in. Old pump was burned out...
-truck still ran like crap. Changed the TPS and the truck ran a little better, but still not good.
-I had no choice but to take the truck to a market on Saturday and barley made it there and back to the farm (100 miles round trip).
-here are the symptoms and codes.....
-terrible gas mileage
-missing terribly on multiple cylinders
-no power going up any incline
-terrible shifting
-it does idle okay
-it starts right up
-seems to run okay when cold for about a mile
-codes0301, p1406, p0174, p0171, p0305, p0303, p0453
If you guys have any suggestions I would really appreciate the help. I need to get this truck running again so that we can keep making it to the markets which are the sole source of income for the farm. Thank you very much in advance.
Mike
East haddam, Ct.
Old Oct 22, 2012 | 06:21 PM
kbsupercrew's Avatar
kbsupercrew
I would go after the 171 and 174 codes first, check the pvc valve on the passenger valve cover and then the hose, follow it back to the back of the intake, check the connecting elbow, these tend to fall apart
also check you dpfe hoses, these are the two hoses that come off the egr tube that connects to the drivers exhaust manifold and the throttle body at the egr valve, these little hoses connect to the dpfe, which a little square sensor mounted on the side of the throttle body
hope this helps
ironrosefarms
Modular V8 (4.6L, 5.4L)
23
Sep 25, 2018 09:46 PM
mossybuk432
1997 - 2003 F150
Dec 20, 2012 07:44 PM
jw040974
1997 - 2003 F150
Mar 3, 2011 08:32 PM
Nimfo
1997 - 2003 F150
Nov 2, 2008 09:37 AM
85rangerman
1983 - 2012 Ranger & B-Series
Aug 1, 2002 04:38 PM
