Sponsored by: Real Truck
P0603 code
Old Oct 21, 2012 | 03:14 PM
jodykc's Avatar
jodykc
P0603 code
I have a 2000 F-350 that is throwing this code. I was wondering if this would affect the way a transmission is shifting. It seems like the torque convertor is not disengaging. It feels like a standard transmission. Any help?
Old Oct 21, 2012 | 10:16 PM
JamesB128's Avatar
JamesB128
Copied from Engine-Codes.Com
P0603
P0603 - Internal Control Module Keep Alive Memory Error
<table style="width:100%; margin-bottom:15px"><tbody><tr><td style="width:25px; vertical-align:top">
</td><td style="width:80px; vertical-align:top">
</td><td style="width:400px; vertical-align:top">
</td><td style="text-align:right; padding-right:0px; vertical-align:top; width:175px">
</td> </tr> </tbody></table> Possible causes
- Loose or poor battery terminal connection
- Low battery charge
- ECM/PCM power supply circuit is open or shorted
- ECM/PCM Programing
- Faulty ECM/PCM
Tech notes
Start by charging the vehicles battery and clean terminal, once the battery is charged and the terminals are clean and secure, erase code. If the code comes back ON you may have to reprogram or replaced ECM/PCM
Read more: OBD2 - OBDII Code P0603 - Internal Control Module Keep Alive Memory Error | Engine-Codes.com
Hope this helps!!
Old Oct 24, 2012 | 08:17 PM
jodykc's Avatar
jodykc
Would this affect the transmission?
Old Oct 24, 2012 | 08:25 PM
JamesB128's Avatar
JamesB128
Im really not a Trans guy but I've seen loose battery connections and bad batteries play havoc on all types of systems. So I would have to say it is entirely possible that the trans could be affected, It is after all controlled by the PCM. How much is controlled by it im unsure but I know things like shift points and line pressure are controlled my it. and an intermittent loss of power to the PCM could cause it to go into limp mode but I would assume other systems would be affected as well.
Sorry I couldn't be of more help.
Old Oct 24, 2012 | 10:57 PM
BigAlsPSD's Avatar
BigAlsPSD
I know in the 7.3 world the P0603 is common if there is a chip installed, or if there has been a modified tune loaded onto the PCM.
What motor is this?
WK57ABF
6.4L Power Stroke Diesel
29
Aug 30, 2020 11:11 PM
dudewayne
Nov 20, 2015 07:23 PM
buddy-z
1983 - 2012 Ranger & B-Series
Mar 10, 2012 12:42 PM
cps
Apr 13, 2008 04:30 PM
beaboarder
Feb 11, 2004 06:08 PM
