Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
C600 questions
Old Oct 21, 2012 | 10:47 AM
Speeddm's Avatar
Speeddm
C600 questions
Good day every one.
Few questions for you all.
First things first the truck is a 66 C600 with a 300-6 and a 4 speed manual.
one issue we have had is starters. one would assume that a 6cyl starter for a manual would fit. But it doesn't. They grind on the ring gear. Last week we did an engine swap and found what I think would cause the confusion. The engine has an adapter plate on the back of it to fit with the industrial tranny. Note what starter should I order? I assume for a V8 but what one.
Wheels and tires are becoming an issue. The truck is running split rims and 7X20 tires. All our local shops tell me I have to upgrade all my wheels cause tires aren't available. Any ideas on how to do this on a budget?
Thanks in advance.
Dave
Old Oct 23, 2012 | 07:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Speeddm
The truck is a 66 C600 Tilt Cab with a 300-6 and a 4 speed manual.
One issue we have had is starters. one would assume that a 6cyl starter for a manual would fit. But it doesn't. They grind on the ring gear.
Last week we did an engine swap and found what I think would cause the confusion. The engine has a standard equipment spacer plate on the back of it to fit with the industrial tranny.
Transmission either a Warner T-18 (reverse is up-towards the dash) or New Process 435 (reverse is down-towards the seat), neither is considered "industrial."
C5TZ-7007-E .. Engine Rear Spacer Plate / ALL 1965/72 C/F500/600 300 I-6 M/T.
Different 240/300 starters: A/T, and several M/T's. 240/300 M/T starter used on Econolines, F100/350's is not the same as C500/600, F500/600.
C/F500/600 300 I-6 uses a different flywheel (2 different as it depends on the clutch size) and ring gear (184T) than an Econoline or F100/350 (164T).
Old Oct 23, 2012 | 01:25 PM
Speeddm's Avatar
Speeddm
Its a 184 tooth ring gear. Just replaced it a few months ago but every starter that we can locate does not work.
I6 Manual grinds on every second or third engagement.
Old Oct 23, 2012 | 01:43 PM
NumberDummy
The plate is between engine/trans, correct?
C2OZ-11002-B .. Starter (Motorcraft SA-660)
1965/72 B/C/F500/600 M/T / 1965/67 Galaxie/LTD A/T 240/289 / 1965/68 Mustang A/T 289.
Old Oct 24, 2012 | 11:55 AM
Speeddm's Avatar
Speeddm
Dont worry about it . 75 F350 390 starter worked perfectly
Old Oct 24, 2012 | 01:18 PM
NumberDummy
Why would I worry and now...you don't have to, either.
jowilker
Apr 13, 2021 01:00 PM
Speeddm
Feb 1, 2012 12:14 PM
the ford man
May 4, 2010 11:01 AM
Blue50F-1
Jul 20, 2009 07:14 PM
Black96Cobra
1983 - 2012 Ranger & B-Series
Mar 14, 2006 03:40 PM
