Transmission Help
Old Oct 20, 2012 | 04:47 PM
chris03x's Avatar
chris03x
Transmission Help
Hey guys new posting here, been a member for a while (theres alot to read on here). Ive got a 03 x with the 6.8 2wd 4r100. It was flaring pretty bad for a while going into lock up, about 2 months ago the flare went away now NO lockup. Its taking more pedal to get moving and alot more slip, once you reach cruising speed tranny goes into high pressure. Told to replace the selonoid pack, got one use from a tranny shop from a tranny that lost reverse, got it home took mine out and found out the new one is not PWM and mine is, I tested my selonoid by putting 12v to pin 1 and 4 and nothing (on the pwm pack) did it to the new pack and it works. My question is what will happen if I put the non pwm in my tranny that orginaly had pwm pack in it? Couldnt find a definitive answer. Thanks in Advance for your help
Old Oct 20, 2012 | 05:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the PCM can even operate the solenoid the converter will SLAM on.
Old Oct 20, 2012 | 06:40 PM
chris03x's Avatar
chris03x
Well I just went and test drove it and it worked, it shifted out fine and went into lock up, didnt feel any different over the old solenoid
ihf-350
Jan 9, 2013 11:01 AM
fullmetalmonkey
Feb 21, 2010 09:52 PM
tttanker
1997 - 2003 F150
Jun 5, 2009 07:54 PM
dieselstroke
Feb 26, 2005 10:06 AM
