Instrument panel wiring
Old Oct 20, 2012 | 12:37 PM
Lee22193's Avatar
Lee22193
03 F250 Instrument panel does not work. Have checked all fuses with a meter. Have already fixed broken wires from the OD button on shifter handle. and also the alternator is not charging. I need wiring diagram that shows the wires comming out the back of the fuse box so I can see if the fuse holder is burned out......or any other ideas??????please help
Old Oct 20, 2012 | 12:46 PM
Lee22193's Avatar
Lee22193
The instrument panel is dead and the alternator will not charge. Found the broken wires in the steering column from the OD switch. checked all fuses and still nothing Help
Old Oct 20, 2012 | 06:04 PM
Franklin2's Avatar
Franklin2
Is it new to you or have you had it for awhile? Did anything happen to coincide with this problem?
Old Oct 20, 2012 | 06:06 PM
Franklin2's Avatar
Franklin2
Autozone has the diagrams. Register, plug in your truck, and look under repair guides.
Old Oct 21, 2012 | 08:28 AM
Lee22193's Avatar
Lee22193
The fuse has blown 3 or 4 times about 3 months apart. when the fuse blows the instrament panel did go dead. changed the fuse and it sarted working again. This time the fuse is not blown. It looks like there is a broken wire or something between the fuse and the dash.
Old Oct 21, 2012 | 03:56 PM
Franklin2's Avatar
Franklin2
Which fuse blows? This diagram shows two different fuses.
AutoZone.com Repair Guide Image
Old Oct 21, 2012 | 05:05 PM
Lee22193's Avatar
Lee22193
Thanks to you, I found the Autozone diagrams. I was the able to find that I did not have 12 volts through fuse 45. I then pulled out the fuse panel and found a burned spot on the curcuit board. Now I need a new fuse box.. Thanks for your tip on autozone it really helped
Old Oct 22, 2012 | 01:47 PM
Lee22193's Avatar
Lee22193
Found a fuse box at a wrecking yard for $125 and put it in....Everything works great. Thanks
Old Oct 22, 2012 | 06:53 PM
Franklin2's Avatar
Franklin2
Thanks for writing back in and letting everyone know what the problem was.
ford4x4s
Electrical Systems/Wiring
22
Jun 21, 2019 02:31 PM
steviebs
1997 - 2003 F150
Nov 14, 2007 12:02 AM
pilldoc
Apr 24, 2005 06:54 AM
1979_F100_302
Jun 17, 2003 09:54 AM
