How much can the computer handle. . ?
Old May 19, 2003 | 07:38 PM
jaimalade's Avatar
jaimalade
Question How much can the computer handle. . ?
Hello All,
I am building an '88 F-250 4x4 for a tow vehicle for all my Galaxies ('65-'67). I'm starting with an EFI 351W. I have built all kinds of motors, and many strokers, but this will be the 1st with EFI (if I keep it that way). I am aware of all of the benifits of EFI over a carb, but if I have to spend ~$600 for a Mass Air conversion kit, then I'll go to a carb. . .
Anyway, what I am asking is, just how far can one go and retain the "stock" computer. I am not opposed to a $200-$300 chip, but not much more. I realize I'm being sketchy here, so how does a "chipped" computer deal with:
*compression upgrades
*different rod lengths
*bore & stroke changes
*ported heads
Please do take a little time and help educate me. Also, it it conceivably possible to get the mass air stuff from a junk yard and adapt it, or is there simply too much "electronic stuff" to deal with.
Thanks,
Nathan
Old May 19, 2003 | 08:13 PM
steve83's Avatar
steve83
I think a late-model MAF swap would be less work than what I did to mine (1-bbl to EFI), so if you want MAF, I say: go for it!
You'd probably get better responses asking this question in the computer forum. Look a little higher ^.
Old May 19, 2003 | 09:33 PM
FTE Ken's Avatar
FTE Ken
You can't go anywhere with those changes on a stock speed density computer because it cannot compensate for air flow changes. You'd need to get a custom tune.
Old May 19, 2003 | 11:35 PM
jaimalade's Avatar
jaimalade
Could you please explain further what a "custom tune" is
Thanks,
Nathan
Old May 20, 2003 | 12:37 AM
Ford_Six's Avatar
Ford_Six
A custom built computer. The computer controls the fuel to the engine by reading a map. This is programmed into the computer at the factory, and bases fuel needs by manifold vacuum, throttle angle, and rpm. A few other parameters refine the mix, but those are the basics of a speed-density system. A mass-air system reads the total weight of the air going in, as well as the throttle angle, manifold vacuum, and rpm. This gives the computer added info to go beyond the factory map, and compensate for heavier mods. Of course, if you are build a 427w or something really radical, you will still need a custom computer. I would try to find a 92-94(?) F-series with a 351 and mass-air, and use the control system from that. You may also want to contact the Diablo chip company you see advertised here (be sure to say you saw them on FTE), and ask if they can make what you need. You will need all of your buildup specs for that, though.
jughead2
Engine Swaps
Oct 28, 2005 08:51 PM
restorit
1978 - 1996 Big Bronco
Sep 24, 2003 10:48 PM
jaimalade
Computer Chips & Tuners
Jul 6, 2003 04:26 PM
jaimalade
Jun 25, 2003 02:24 PM
jaimalade
May 27, 2003 10:12 PM
