Gear Change
Old Oct 19, 2012 | 08:35 PM
randytk2's Avatar
randytk2
Gear Change
I recently bought an 05 Lariat with a 3:55 rear end. I am looking to change that out to a 3:05 to increase my fuel mileage. What kind of gain can I expect after I do this. The truck has the 5.4 engine and runs really well I just need to get better mpg. Any thoughts or ideas would be appreciated.
Old Oct 19, 2012 | 10:47 PM
seventyseven250's Avatar
seventyseven250
In my opinion, you probably aren't going to save enough gas to pay for this modification.
Old Oct 20, 2012 | 08:25 AM
Gundown64's Avatar
Gundown64
I would have to agree with this. Gear changes are expensive. If you have a 4x4, you can double the price as well. Plus, I think you will beat yourself up over the performance decrease you would get. 3:05s are going to suck on the performance end.
Old Oct 20, 2012 | 02:37 PM
seventyseven250
First question should be, what mileage do you currently get, in what kind of driving, how heavy is your foot.
Drive for a week with a very light foot, and re-calculate your mileage again.
Old Oct 20, 2012 | 03:48 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
1. Expense: figure about $700 per axle
2. Economy: on paper you should see a MPG gain, but in reality you will see it go down. Your motor in overdrive is designed to work at a certain rpm. Raising the gear ratio will drop it out of that rpm range. You'll be lucky if it can maintain 4th at 60 mph
Old Oct 20, 2012 | 04:23 PM
1969furd's Avatar
1969furd
i was going to o the same thing, you would only drop ~400 rpm, you wont ever recover what you spent on it.
Old Oct 20, 2012 | 07:13 PM
danorules's Avatar
danorules
I agree with the rest, gears are not a cost effective mpg saver. Driving style will help more than anything.
Also, if you want good gas mileage a full size truck was a poor choice
Old Oct 29, 2012 | 07:26 PM
nrfd's Avatar
nrfd
I have a 2007 F150 V6 5 Speed, I changed the gear ratio from 3.31 to 3.73 and my gas mileage improved. The change you are contemplating will disappoint you from both a performance and economy perspective.
Old Oct 29, 2012 | 08:54 PM
Beechkid's Avatar
Beechkid
For each .25 gear ratio change,the rpm's change by 300....so that will give you an idea...probably see 1-2 MPG gain hwy, probably loose 1-2 mpg city.
sparke454
Nov 8, 2009 05:55 PM
Mustang-F150
2004 - 2008 F150
Oct 18, 2008 09:03 AM
PHS79
2004 - 2008 F150
21
Oct 27, 2005 03:09 PM
jet35a
1983 - 2012 Ranger & B-Series
Feb 22, 2003 06:22 PM
