DPFE Sensor Location E150??
Anyhow, here are some pics of the old elbow - a little dirty inside and it isn't perfectly rounded on the corner, but I don't see any holes in it. Any other ideas? I can't seem to trace the hose itself to the other end because I can't even see anything in its crappy location (I'm really frustrated at how difficult this van has been to access parts if you can't tell). Any other ideas by chance for the running lean codes?
If you have a normal carb then try adjusting the mixture screw (adjusts the amount of fuel flow for throttle position) thats on the carb. If you have a repair manual the technique for adjusting the mixture should be in there. I always used a vacume gauge on carbs. This guys has a different best high rpm method.
Good luck getting things fixed up to your likings.
i thought i was gonna have to replace the dpfe sensor but looks like i dont as i dont have any more idle issues or codes. i also replaced the 'pcv valve' grommet as it was a loose fit for the pcv valve. dont give up, your almost there. Best of luck!
i thought i was gonna have to replace the dpfe sensor but looks like i dont as i dont have any more idle issues or codes. i also replaced the 'pcv valve' grommet as it was a loose fit for the pcv valve. dont give up, your almost there. Best of luck!I drove the van and about 3 miles into the drive the CEL came on. Pulled over and scanned it. P0174 was the only code, and the P0171 was no longer tripped. Down to one code. Drove about 6 miles stop & go traffic and scanned again. Still only the one code.
Only had less than 1/4 tank of gas in it so went to the gas station and filled gas to 3/4 tank then cleared codes with the scanner.
Drove away and hopped on the highway putting about 15 highway miles on it around 60-70 mpg. No CEL. Back into town, about 5 city miles driving, 20-35mph stop & go traffic. No CEL.
20 total miles on it so far, stopped and scanned it. Two codes showing as pending: P0171 and P0174.
Started up again, few more miles city driving. Scanned it. Still pending codes.
Few more miles and got back home and parked it, scanned it. Still pending codes.
What is the deal with pending codes? Do they ever go away or am I still not there yet with part changing? I don't have a garage so it would be hell pulling out the MAF sensor and cleaning it, and the more I work on it on the street, the more I'm risking getting a ticket...if the pending codes go away somehow I should be in the clear. Any further advice?
Pacific, I did try an additive but might try that seafoam stuff, looks like it gets good reviews.
Down to:
- fuel filter
- smoke test to check for vacuum leak somewhere else
- dirty MAF sensor
- o2 sensors
- something as simple as the gas cap or oil dipstick maybe still? both are original oem...
While the intake was off, I did a visual inspection of all the vacuum hoses I could see and felt the undersides for any cracks - looked good. Also did a visual and physical examination of the intake for any cracks, holes, etc. Again, looked good. Air filter very clean, new within the last 3000 miles. Oil dipstick was seated as well as I could tell.
I reinstalled the MAF sensor and intake and fired up the engine. It sounded better for a few minutes and then started to purr again like before. I still don't think it sounds like a vacuum leak but not 100% sure.
Bought a new fuel filter anyway since it's a bit sluggish to start after sitting for a few days and will install that if the codes come back on after a drive cycle tomorrow. I'm not gonna let this damn emissions crap get the best of me and can't afford to take it in for a pro to smoke test it or diagnose it.
This is turning into a diary, I know, but hopefully it serves as a good resource to people in the future with the same codes popping up - they seem popular. Feedback is still welcome.
I took it out today and did some driving to get the monitors set. The codes came on as pending again and here is what my OBDII monitors look like:
MIL - off
Misfire - Ready
Fuel - Ready
CCM - Ready
Cat - Ready
HCM - n/a
EVAP - not ready
2air - n/a
A/C - n/a
O2s - not ready
HO2s - not ready
EGR - ready
Pending codes: P0171 & P0174
So apparently N/A means that the vehicle is not equipped with those monitors, is that correct? So in that case the O2s and HO2s are the only ones left to set (along with the EVAP which is hard as hell to get it ready?)
If the EGR monitors are ready and the codes are only pending then would that mean the EGR system is all back to good again and maybe it's the O2 sensors that aren't on? If so, what could I possibly due other than replacing them? At $45 each in parts, that's $90 to $180 to replace - yikes..
Also, do you think I'm safe to not change the fuel filter at this point? That's $30 I could save by not changing it...
I took a video and will try to figure out a way to upload/embed it.
I'm about at a loss here, what are your thoughts? Thanks!
MIL - off
Misfire - Ready
Fuel - Ready
CCM - Ready
Cat - Ready
HCM - n/a
EVAP - not ready
2air - n/a
A/C - n/a
O2s - not ready
HO2s - not ready
EGR - ready
As far as the EVAP goes, im not sure what that is but i did come across this upon googling it --> 2002 ford e-150: van..V6..I cleared out an error code (cyl 3 misfire) - JustAnswer
Seems you may just have to complete a drive cycle of 10 minutes where u have to cruis 45 to 65mph w/o any hills or sharp turns. Then maybe it will turn ready?
Not sure if you should change the fuel filter just yet, i say check the grommet 1st and go from there. Good Luck
I then cleared the codes yet again. Finally got around to a drive cycle tonight and here's what I have now after the drive cycle I did:
MIL - off
Misfire - Ready
Fuel - Ready
CCM - Ready
Cat - Ready
HCM - n/a
EVAP - Not Ready
2air - n/a
A/C - n/a
O2s - Ready
HO2s - Ready
EGR - Ready
Pending codes: P0171 & P0174 showed up again, but still only as pending.
If anyone knows, will this pass CA smog with one monitor (EVAP) not ready? It's damn near impossible to find an area where I can drive 60mph for 10 minutes straight in LA.
Thanks for everyone's continued assistance.
