Cold wether operation
Old Oct 21, 2012 | 05:28 PM
Yahiko's Avatar
Yahiko
Ok let me add this.
I put any additive in when I fill my tank.
Most if not all the places I get fuel at
are under ground tanks. So really the only time
it is locally stored above ground is when it's in my truck.
I use the Ford PM-22a all the time
and from this post I see where Cheezit says to use both when the temp drops
if I am understanding him
https://www.ford-trucks.com/forums/9...s-pm-23-a.html
Sean
Old Oct 21, 2012 | 06:58 PM
roadrunner01's Avatar
roadrunner01
I'm not familiar with the Ford fuel additive, I use the John Deere(Stanadyne) fuel additive.
They offer a summer formula and a winter formula, the winter formula does everything the summer does PLUS anti-gel protection, so theres no need to use both at the same time.
I would guess the Ford diesel fuel additive does the same, as I have read that Stanadyne bottles it for Motorcraft. Although I'm sure a company can specify whatever specs they want in an additive I doubt the need for two different additives to be used together.
You should be able to look up the motorcraft specs on this to verify.
vinnie_p
Oct 30, 2017 03:02 PM
rmilchman
Oct 23, 2008 01:25 PM
wreckit72
General Diesel Discussion
Feb 13, 2007 12:52 AM
Duane99
Feb 9, 2005 07:55 AM
chrison600
Dec 11, 2003 06:16 PM
