E4OD Compatibility question Years / Models
Old Oct 18, 2012 | 03:19 PM
Rentaro's Avatar
Rentaro
Question E4OD Compatibility question Years / Models
I have been reading in various places that either the 95 or 96 is the best vehicle to get your replacement E4OD transmission.
Supposedly these ones have the most upgrades?
I have a 1990 F250 4x4 with the 460 engine in need of an E4OD.
Now when I search car-part.com it only lists 1989-1991 year trucks as the donor. I was surprised not to see all the way up to 96 year trucks listed, or even vans for that matter.
Could anyone please verify if I can use an E4OD from a 95/96 truck or van as long as it has the 460 engine?
Old Oct 19, 2012 | 09:55 AM
Rentaro's Avatar
Rentaro
contradicting information
Here is another example, it is advertising the transmission will work for 1991-1998, I keep getting contradicting information on what year vehicle the transmission can come from:
Ford E4OD Rebuilt Transmission 460 CU in Engine 1991 1998 1987 | eBay
Old Oct 19, 2012 | 10:00 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/1...-question.html Click on this link and read the post by subford on the diodes.
As he advises you would need to change the solenoid blocks over.
Old Oct 19, 2012 | 12:00 PM
Rentaro's Avatar
Rentaro
Thank you so much for the reply!
This is good news, now I can shop around for a newer year transmission without worrying that it wont work.
it looks like the last year for the E4OD is 1998, and the first that had all the factory improvements was 1995?
so I should be looking for an E4OD from 1995-1998?
Is the solenoid blocks the only difference between years and the different models? Bronco/E-Series/Expedition?
From your reply it sounds like I can definitely use a newer year E4OD from a truck, I just wanted to make sure it could also come from the E-Series van.
Wikipedia lists (E4OD http://en.wikipedia.org/wiki/Ford_C6_transmission):
1990–1996 Ford Bronco (95-96)? Nope, did not come with a 460
1989–1998 Ford E-Series (95-98)? only 95-96 had a 460, but not sure about 4x4
1997–1998 Ford Expedition (95-98)? Nope, did not come with a 460
1989–1998 Ford F-Series (95-98)?
EDIT:
I should probably just find one from a truck to be on the safe side, Just did a search for one from a newer truck and there seems to be plenty to choose from with trucks alone, without getting into vans or broncos/expediations
(Although an E4OD from a E-Series Van has probably had less abuse than one from a truck that has probably been haulin some loads in its life, not always the case but I figure probably true on average.)
johnguc
Mar 22, 2021 07:50 AM
RRE101
Jun 14, 2010 07:57 PM
phatfantom68
Feb 21, 2008 02:34 PM
trike1946
Jun 26, 2005 07:56 PM
