General Diesel Discussion
Winter - weight
Old Oct 18, 2012 | 12:19 PM
QUINCE's Avatar
QUINCE
Winter - weight
Just popped up in my mind: with winter around the corner, is it better to add weight in the box, or down on the axel; in other words, weight is better above suspension, or below?
Thanks for your opinions!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Oct 18, 2012 | 12:51 PM
85e150's Avatar
85e150
In the box, ahead of the axle, preferrably braced against the front so it won't move. Sand or kitty litter is good as you can get some of the contents and use them for traction on ice or compacted snow. Good tires recommended also.
Old Oct 22, 2012 | 09:25 PM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
I have always put the weight directly over the axle in the bed. This puts the most weight on the rear wheels without adding weight to the front wheels where you don't need it. You also don't want weight all the way in the back because you want it as centralized as possible to where you want the weight effecting the wheels. Far back weight is just as bad as high weight.
Old Oct 31, 2012 | 11:58 AM
nitrogen's Avatar
nitrogen
eh if i'm adding weight i'll add it as far back as I can. I have a nice heavy diesel, and a ranch-hand winch and bumper on the front. I never carry weight just for the sake of weight but it needs all the counter balance it can get. I have seen some guys use the weight plates from a tractor. they built a false floor out of wood planks with cutouts to fit the weights.
usmcar15
All Things Towing
Sep 11, 2011 07:26 AM
88Vmax
All Things Towing
Jul 15, 2006 04:18 PM
seth1
1983 - 2012 Ranger & B-Series
Jul 16, 2005 10:16 PM
scrape
Apr 12, 2005 05:23 PM
