TSP problem I think
Old Oct 17, 2012 | 07:40 PM
chris86924's Avatar
chris86924
TSP problem I think
Hi All,
Over the weekend while driving to Reno, In my 2000 F250 PSD I had an issue where sometimes It would just start to Surge. It also felt like I lost all power for a minute and then it would come right back. I replaced the whole Peddle Assembly back in 2009 when I bought the truck due to the fact that the truck would loose power. This time it seems ok then all the sudden will just jerk forward like it got a whole bunch of fuel at one time. I also noticed this when I was driving on Interstate 80 it was kind of doing the same thing. I am wondering if it is the same issue or something else possiblibly. I have a Thottle Postition Sensor on order, I just wanted to be sure before I headed to Santa Cruz for the weekend.
Thanks
Chris
Old Oct 17, 2012 | 08:10 PM
BigAlsPSD's Avatar
BigAlsPSD
It is a possibility that the TPS is the culprit again...could be other things such as IPR, or ICP, even fuel pressure related if dropping low enough.
Are you getting any codes?
What about oil level and condition?
Old Oct 17, 2012 | 08:21 PM
chris86924's Avatar
chris86924
The truck is throwing no codes and and the Oil was changed on Friday before I left to Reno the only difference is that I put rotella in it instead of the Delo I normally put in.
Old Oct 17, 2012 | 08:33 PM
guitarpicr's Avatar
guitarpicr
Thought there was a way to clean the tps. Might just be dirty. Try a search for cleaning tps. Edit - Might be a dirty Idle validation switch
Old Oct 17, 2012 | 08:37 PM
BigAlsPSD's Avatar
BigAlsPSD
Yes, you can remove the pedal assembly and spray it down and clean it with electronics cleaner, I do it with Yearly PM.
Old Oct 17, 2012 | 09:16 PM
chris86924's Avatar
chris86924
Ok I will try to clean it. Thanks for the help!
Old Oct 18, 2012 | 07:02 AM
Tugly's Avatar
Tugly
New oil type? IPR is highly suspect. I just went through this after I replaced my injectors. My old IPR got a taste of fuel and air in the oil and went on the rampage (uber-throttle). Luckily, I had my engine analyzer recording when it happened, so I saw precisely how it happened. I replaced my oil because that's what you do with new sticks, and I replaced my IPR because it was old and flakey. While the TPS can cause issues, it is electrical and pretty darned reliable... where the ICP sensor and the IPR are electro-mechanical and come in contact with the oil. It's likely the oil will work itself out and the problem will subside/disappear, but I don't recommmend hopping back and forth between oil types. The injector gurus recommend synthetic oil for better injector life and the tuning guys recommend an oil weight of 15-40 for better tuning consistency. Most synthetics are 5-40, but the really expensive synthetics are 15-40... choose your compromise.
Tick..tick...tick.... I'm just waiting for somebody to chime in and point out the err of my information.
Kadin Cook
20
Feb 18, 2019 02:06 PM
bly8397
Dec 17, 2012 03:15 PM
foppyween
1983 - 2012 Ranger & B-Series
Aug 20, 2009 07:21 AM
Roadgrinder
63
May 6, 2009 01:53 PM
woody1333
May 16, 2008 09:58 AM
