Sponsored by: Real Truck
Trailer power need
Old Oct 17, 2012 | 05:47 PM
robertcoogan's Avatar
robertcoogan
Trailer power need
I have a 2006 Ford F-250 Super Duty diesel crew cab, and want to get a trailer to collect veggie oil in. I want a small trailer, and have found some on Craigslist pretty cheap that seem to fit my needs. But I want to be able to run a small pump to transfer the oil from the collection barrels to 55 gallon drums that I will have on the trailer.
My question is, what sort of power needs should the pump have for me to run off of the truck's power while it is parked (but engine running)?
Old Oct 17, 2012 | 05:51 PM
redford's Avatar
redford
FTE Leadership Emeritus
It should run off of 12 volts, and probably not draw more than 5 or 6 amps.
Old Oct 17, 2012 | 05:55 PM
robertcoogan
Many thanks!
Old Oct 18, 2012 | 08:43 AM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
I would mount a battery on the trailer along with the pump. Then the 12v from the truck could keep it charged but not have to handle all of the load.
Old Oct 18, 2012 | 11:03 AM
meborder's Avatar
meborder
what he said.
be sure to fuse the wires at the battery on the trailer. I use a 20 or 30amp self-resetting circut breaker when mounting a coach battery. if it ever draws too much current it will reset on its own without having to chase down a blown fuse.
creative wiring allows you to run all the wires to a post on the trailer and protect the whole works with one circut breaker.
skibuoy
All Things Towing
Jun 3, 2019 07:34 AM
Slackerme
Dec 8, 2018 05:06 PM
gman97005
General Automotive Discussion
Feb 2, 2016 12:03 AM
phydeauxman
Mar 24, 2014 10:32 AM
f350xlt460
All Things Towing
Dec 15, 2003 05:27 PM
