Big block camshaft
Old Oct 17, 2012 | 12:06 PM
AP3X's Avatar
AP3X
Big block camshaft
I've got a '95 F250 with the stock 460. I've been looking around online for my camshaft options and was puzzled that no one lists a Comp Cam for a 95. The cutoff is 94. I know that mass air came on some 96-97 trucks (my truck is SD), but I can't see how there is could be any difference between a 94 and a 95 engine that wouldn't allow me to install an aftermarket camshaft. Should I worry about this, or just go for it?
Old Oct 17, 2012 | 02:49 PM
DIYiT's Avatar
DIYiT
It might be that in '95 some states (California) had MAF on the truck while most states kept the SD system. They may want to avoid problems based on ordering the cam based solely on the year. The '94 compatible cam should work.
Old Oct 17, 2012 | 11:41 PM
CS79bronco's Avatar
CS79bronco
I don't know what the difference would be, but when I had a 91 460 rebuilt last winter I wanted to run an "RV" cam. My machine shop guys wouldn't do it. They said to change cams would lower the vacuum, causing the ECM to "think" the engine was accelerating, thereby dumping too much fuel. Then mpg would go down and it would run lousy.
Old Oct 18, 2012 | 01:28 PM
AP3X's Avatar
AP3X
Comp cams have 3 speed density friendly cams for the efi 460
landtortise89
Jun 5, 2019 08:52 PM
RacinNdrummin
Jul 5, 2007 09:58 PM
fatboyf150
Jan 16, 2007 12:04 AM
byoungquist
Sep 2, 2006 06:58 AM
MW95F250
Jan 26, 2003 10:22 PM
