intermittent rough idle
Old Oct 17, 2012 | 09:28 AM
imtryin's Avatar
imtryin
Got a '97 F250 7.3 5-speed that idles rough sometimes. Looks like the rpm drops too low when this happens. Throttle switch voltages measure good. Happens more often when it is warm outside and engine is up to operating temp. I was wondering if this is a flywheel issue? New glow plugs and cam sensor already installed. Like I said, this is very intermittent, and if I hit the throttle and bring the rpm up, the engine smooths out.
Rough idle may be an understatement- if I don't goose the throttle, it shakes the entire front end of the truck. Truck runs fine otherwise. Suggestions? Thnx.
Old Oct 17, 2012 | 09:48 AM
CampSpringsJohn's Avatar
CampSpringsJohn
You have 2 trucks that do this?
Old Oct 17, 2012 | 09:50 AM
CampSpringsJohn
How long have you owned the trucks?
Miles?
Have you done any modifications to the trucks?
Last oil changes? What kind of oil?
Old Oct 17, 2012 | 02:29 PM
imtryin's Avatar
imtryin
The 2 was a typo.
Mileage is 262k. Truck is completely stock.
Owned it for about three years.
Old Oct 17, 2012 | 09:53 PM
stainlessstroker95's Avatar
stainlessstroker95
Try unpluging the icp sensor and see if it runs better, and also look and see if it has oil in the connection.
Old Oct 17, 2012 | 10:24 PM
CampSpringsJohn
I agree with checking the ICP plug. The mileage tells me you may be due some injector work too. You didn't say when the last oil change was, or what brand and weight oil you used. Also, when you change the fuel filter, is the filter black or dark blue? Is the diesel fuel in the filter housing discolored?
bryanj
Aug 27, 2009 07:18 PM
C90RanMan
Apr 8, 2009 12:15 AM
tony mathers
35
Oct 4, 2007 11:48 PM
Ed the outdoorman
Dec 23, 2003 04:35 PM
