What size tires
Old Oct 17, 2012 | 09:22 AM
strokerpower7.3l97's Avatar
strokerpower7.3l97
What size tires
I have a 97 f250 4door short bed lifted and a straight axle swap with 35 nitro trail grapplers on it right now, I was thinking about putting the same kind of tires on it because they work so great but I wanted to put 37 on it. Has anyone put 37 on a 4in lift. And if you had please post pic so I can see what it looks like. Thanks
Old Oct 17, 2012 | 02:13 PM
glovemeister's Avatar
glovemeister
If you have 4.10s I would run no more than 35s. If you have 3.55s no higher than 33's. I really regret going up to 35s with my 3.55 gears.
Old Oct 17, 2012 | 06:26 PM
strokerpower7.3l97
i have 4.10 gears, it still really moves even with 35s, but the thing is my tranny slides in to gear if you get on it and i dont know if it will take any bigger tires but other then that its perfect, and its a brand new tranny like 4000 miles on it but i plan to get it built. and also having a programmer plays a part in it, if i have it on stock it shifts perfect no matter what. it just seams like guys are all going to 37s now
Old Oct 17, 2012 | 06:42 PM
glovemeister
A lot of guys are also burning up trannys or spending $4k for BTS or Suncoast too... If your tranny only has 4k and it is slipping something is wrong, or it was beat on.
Old Oct 17, 2012 | 06:44 PM
strokerpower7.3l97
i dont know if its really sliping its just not shifing hard its because of the tranny
Old Oct 17, 2012 | 07:00 PM
glovemeister
Have you looked at getting some custom tunes?
Old Oct 17, 2012 | 07:13 PM
strokerpower7.3l97
YEAH I HAVE BEEN THINKING ABOUT THAT I REALLY DO WANT TO, BUT I WAS ALSO LOOKING AT THE EDGE CTS, ON THE CUSTOM TUNE LIKE THE 6 GUN ONES ARE THE SHIFT ON THE FLY? BECAUSE I REALLY LIKE THOSE
Old Oct 17, 2012 | 08:27 PM
Lazy_pig's Avatar
Lazy_pig
i have 37s with a 4 inch lift solid axle swap 4.10 gears no problems thus far havent had them on long tho
Old Oct 18, 2012 | 11:19 AM
strokerpower7.3l97
yeah i dont think i will have to much of a problem its just a lot of tire to turn, like when you have a heavy trailer and its a lot to stop
Old Oct 18, 2012 | 11:52 AM
fordman67's Avatar
fordman67
Get some custom tunes.do a search to see all the bad edge stories.
Old Oct 18, 2012 | 01:56 PM
strokerpower7.3l97
i like the custom tunes
Old Oct 18, 2012 | 06:48 PM
Lazy_pig's Avatar
Lazy_pig
i agree custom tunes are the way to go
Old Oct 18, 2012 | 07:13 PM
strokerpower7.3l97
ARE THEY SHIFT ON THE FLY
Old Oct 18, 2012 | 11:32 PM
stainlessstroker95's Avatar
stainlessstroker95
Yes they are.
Old Oct 18, 2012 | 11:50 PM
Lazy_pig's Avatar
Lazy_pig
most of them plug directly into the side of the ecm and shift on the fly. the cts plugs into the obd2 port and you have to shut off the truck to change tunes
