99' e250 ext, coolant temp is dropping into "C"
Old Oct 17, 2012 | 05:56 AM
wizzy214's Avatar
wizzy214
1999 e250 ext cargo. 287k
the coolant temp seems to be dropping, as a few weeks pass its normal in the middle. now it seems its getting lower and stays there. everyday starts and runs fine. temp warms up as i drive but the needle seems to get lower. like lower than yesterday. just seems like its lower than normal. fluid is all there.
Old Oct 17, 2012 | 09:57 AM
Tom's Avatar
Tom
It could be a bad thermostat, sensor, or an electrical issue with the sensor. I would start by replacing the thermostat; they're inexpensive and can be a common source of temperature problems.
How has the cooling system been maintained? Has it been changed every 30,000 miles like it should have, or has it been neglected?
Old Oct 17, 2012 | 12:04 PM
joshofalltrades's Avatar
joshofalltrades
i would plug in my OBD2 code reader and tell it to monitor coolant temp on the code reader's screen while i took it for a drive. if its not good and warm in a couple miles, you need a thermostat. but if it is up to a proper temperature, then you have issues somewhere in the gage system.
with winter coming on, you want that sucker to get nice and warm and stay there
Old Oct 17, 2012 | 12:05 PM
blageurt's Avatar
blageurt
Yes I agree with above statement...the only other thing I would add is to try and check / verify the temperature with one of those point and shoot thermal guns to see if it is the actual temperature it is supposed to open at, or if your guage is doing the mambo....
Old Oct 17, 2012 | 05:06 PM
wizzy214's Avatar
wizzy214
what should it read at normal temp? ill try it today.
Old Oct 17, 2012 | 06:22 PM
blageurt's Avatar
blageurt
The temperature it should read is whatever your Thermostat is rated for......
Old Oct 17, 2012 | 06:39 PM
Tom's Avatar
Tom
Most are around 185° F.
Old Oct 18, 2012 | 12:00 AM
joshofalltrades
its definatly somewhere between 180 and 200. i would have guessed it came stock with a 195.
with a good thermostat, you should be up to operating temp within 2 miles of driving unless its really cold where you are. a thermostat thats stuck open will take much longer to find a steady temp, which will probably be pretty cold like 150 or something
Old Oct 18, 2012 | 09:02 AM
wizzy214's Avatar
wizzy214
after driving for an hour to work obd2 said it was at 197 degrees. sitting at idle it went to 199.
ill plug it it when i start driving and see how long it takes to get warm, tomarrow.
Last edited by wizzy214; Oct 18, 2012 at 09:06 AM. Reason: a little birdie told me too.
Old Oct 18, 2012 | 09:06 AM
Tom's Avatar
Tom
And did your gauge start reading lower after awhile, or did it stay constant?
Old Oct 18, 2012 | 09:37 AM
wizzy214's Avatar
wizzy214
i only watched it for about 2 mins.
ill leave it plugged in all the way tom. and see what it says.
i got like 4 trouble codes too.
Old Oct 18, 2012 | 09:42 AM
Tom's Avatar
Tom
Sounds good, can you post the trouble codes?
6.0ForLife
Apr 20, 2019 03:52 PM
tbar1963
6.2L V8
Apr 1, 2017 10:49 AM
billbot
Jul 8, 2012 08:48 PM
me Mickey C
13
Feb 10, 2008 12:32 AM
The Grinch
May 21, 2003 06:17 AM
