Bronco lift problems
I have just put in a 2" lift on my 81 bronco and everywhere I have read wouldn't need TTB extensions. I have big problems with camber and caster even with camber and caster adjustable bushings in still have too much even for them. Seems like having all problems with 4" lift but with only 2". Was hoping not to put traction beam extensions on as I do a lot of off roading and herd they are not very strong. All help will be appreciated thank you.
Received 3,171 Likes
on
on
on
if you put a 4 inch drop bracket in, you will go around 4 degrees the other way. too much for a cam.
the only way to do it properly is to put a 2 inch drop on it.
on the three trucks i did, i put 0 degree cams in, set the truck on a level pad, and cut the brackets and add whatever was needed to get the alignment where it needed to be. once welded i then align the front end.
You can buy all that stuff individually at suspension connection.
Miscellaneous Lift Kit Parts by Tuff Country
Turlz
10-28-2012 11:35 AM
