Ok I did some plug and wire pulling to day and I ran and got a new plug to see if it was just the plug and it is still making weak spark so I shoved my finger inside the wire and it didn't seem like it gave me a good shock. So I'm thinking the coil is dead.
Make sure when you do that test you ground yourself out to the truck. A bad coil does not descriminate so if the coil is bad you would have a bad spark at all plugs
Yea I held onto the manifolds . All the plugs are like that. The only reason 6 isn't firing is because it has lower compression and the spark just isn't enough to light it.
