390 Problems
Old Oct 16, 2012 | 08:21 PM
1975MudRat's Avatar
1975MudRat
Ok I'm thinking that the coil is bad.
Old Oct 16, 2012 | 08:22 PM
1975MudRat's Avatar
1975MudRat
Originally Posted by Bullitt390
In a GAS engine:
Black smoke is rich
White is coolant
Blue is oil
In a DIESEL engine:
Black is poorly combusted fuel
White is unburnt fuel or coolant
Blue smoke is engine oil
Josh
Ok, then why is it when you pour oil in a glass pack it is as White as a cloud?
Old Oct 16, 2012 | 08:53 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I'll say oil in the exhaust is nowhere near the same as oil entering the combustion process.
Blue Smoke vs. Black Smoke | Car Trouble | Autobytel.com
Josh
Old Oct 17, 2012 | 05:33 PM
1975MudRat's Avatar
1975MudRat
Josh
HAHA ok. I like how we are actin like 4 year olds fighting over smoke lol!
Old Oct 18, 2012 | 12:50 AM
1975MudRat's Avatar
1975MudRat
Ok I did some plug and wire pulling to day and I ran and got a new plug to see if it was just the plug and it is still making weak spark so I shoved my finger inside the wire and it didn't seem like it gave me a good shock. So I'm thinking the coil is dead.
Old Oct 18, 2012 | 12:54 AM
stromburg's Avatar
stromburg
Make sure when you do that test you ground yourself out to the truck. A bad coil does not descriminate so if the coil is bad you would have a bad spark at all plugs
Old Oct 18, 2012 | 12:58 AM
1975MudRat's Avatar
1975MudRat
Yea I held onto the manifolds . All the plugs are like that. The only reason 6 isn't firing is because it has lower compression and the spark just isn't enough to light it.
wag53
Aug 6, 2017 09:09 AM
bigslick92
Jan 6, 2016 10:27 PM
JimiLL
15
Dec 9, 2014 12:02 PM
1975MudRat
Oct 18, 2012 12:48 AM
bgirard78
1983 - 2012 Ranger & B-Series
Dec 17, 2007 06:33 AM
