Longbed to shortbed conversion
Old Oct 15, 2012 | 09:10 PM
hath's Avatar
hath
Is it possible to just move the axel and its components forward to accomodate a shortbed and then simply cut the excess frame off? I'm asking this to avoid taking a long bed and cutting it up to look like a short bed.
Old Oct 15, 2012 | 09:23 PM
arctic y block's Avatar
arctic y block
What about the hump in the frame that the rear rides in. I think I would cut the frame somewhere in the middle an shorten it that way. Better yet comb the yards and find a short frame to start with.
Old Oct 15, 2012 | 10:46 PM
lilsmokey's Avatar
lilsmokey
Welcome to FTE! You'll like it here.
What ive seen people do is take the bed off (Of course) and driveshaft and brake lines. Then cut the frame 2 or 3 inches behind the cab. HAVE IT SUPPORTED!!! Then from there cut 16 inches (dont quote me on that) off.
Then weld the back half (Now shortened) and the front half (Cab and engine) together. Make sure it can handle the stress of constant driving. Now all of your bolt holes will hopefully line up for the short bed. Now add exhaust, shortbed brake lines, driveshaft, and wiring. Walah! Shortbox.
Keep in mind if it is a 2wd 3/4 tome truck when you convert it, it will be really high in the back and lean forward alot more than a lwb.
Im sure someone on here can find a link or to, to a conversion.
Old Oct 16, 2012 | 12:02 AM
HIO Silver's Avatar
HIO Silver
Keep in mind if it is a 2wd 3/4 to me truck when you convert it, it will be really high in the back and lean forward alot more than a lwb.
Here's a good one: The FORDification.com Forums • View topic - 72 F100 project, longbed to short conv, CV swap, 20s
Old Oct 16, 2012 | 04:56 AM
jowilker's Avatar
jowilker
hath, You can but it is a heck of a lot of work. From your post I get that you already have the short bed that you want to use.
I would buy another swb truck using it's title & chassis, and move your cab & front clip to the newer chassis. 65-72 chassis are the same size, so you have choices. If you are doing the power steering upgrade you could do all that at the same time.
The cab & front clip can be lifted as one piece, roll one chassis out the new back under. Much simplier.
John
Old Oct 16, 2012 | 10:24 PM
elgemcdlf's Avatar
elgemcdlf
If memory serves me right (can't count on that) the '65/'66 chassis is 2" shorter in wheelbase than the bump chassis. Again I am not positive on that.
Old Oct 17, 2012 | 07:48 AM
Freightrain's Avatar
Freightrain
Seems there was another good post just recently that showed a fellow cutting up his long bed(it was 4x4?). It was plain stock,unlike the one posted above that changed the suspension.
Old Oct 17, 2012 | 07:51 AM
Freightrain
Found it:
https://www.ford-trucks.com/forums/1...9-f-100-a.html
Old Oct 17, 2012 | 02:52 PM
boo-yaa138's Avatar
boo-yaa138
yep that my truck in the post. it was super easy to covert it. BTW my truck is 2wd not 4x4.
Old Jan 29, 2013 | 07:55 PM
Maidstone's Avatar
Maidstone
Hey I took a 65 long bed and made a shortbed as well looks great lot of layout to get it write, you no the old saying measure twice cut once.
Notmeofficer
Dec 14, 2016 11:31 PM
1956f100
Sep 16, 2007 09:13 AM
jecsd1
Jan 13, 2006 04:10 PM
70sc
13
Feb 13, 2005 12:29 PM
tcozart
May 19, 2003 10:57 AM
