I'm replacing a hub on my '93 Explorer. The manuel says I need to torque tighten the 2 1/8" nut when installing the new hub. I don't have a socket that big. Can I just use channel locks and quess-timate the tightness? Thanks.
I wouldn't advise it - you'll just chew up the nut to the point that you'll need a new one, and you'll never get it tight enough. Most parts stores sell the socket, and the price ranges from $12-60. Check this site - that link takes you to the socket for '95-96 Broncos, but if you surf the site, you'll find yours.
Definitely Buy the SOCKET! I am sure you will use it again and again. I have 3 of them, 1 in each of my broncos and one in my home tool box - both of my Broncos each have an extra set of hubs as well.. you just never know when you will have to swap them suckers out!
so you people with the socket, do you also use a torque wrench out in the field too?
I tighten hubs with vise grips all the time... never once had a problem... logged a combined 60k miles last year on my vehicles, and every one of them I tightened the hubs with vise grips!
Sure. But first, you have to get the vise-grips INTO the hub and lock them onto the nut, with only ~1/2" clearance between it & the hub, plus a ~1" shaft in the way.
