Brake and ABS LIght
Old Oct 15, 2012 | 02:14 PM
aduckfan's Avatar
aduckfan
Brake and ABS LIght
Hi all, new to forum looking for a little help. I did oil and fuel filter service on my 1997 F250 7.2 for the first time and like a knuckle head I let the fuel drain down to a pan under truck without directing it to a container. Next day brake and ABS lights are on continuously. Just had new master cylinder installed. I don't believe to much in coincidence so I assume the diesel fuel contaminated a sensor. Not sure where to look for ABS sensor since it's tough to find a good service manual for this truck. Everything works normally except of course the cruise control.
Old Oct 15, 2012 | 02:23 PM
DIYMechanic's Avatar
DIYMechanic
Welcome to the site aduckfan!
Honestly I don't think that anything you did in draining the fuel has a bit to do with the issue you're seeing. These trucks only really use one sensor for the ABS and it is on the rear differential (far out of the reach of any fluids you were draining). Check the brake fluid level. I bet it is low.
If it isn't the fluid level, then my next question would be, does your speedometer work? If the sensor on the rear end is out (VSS -- Vehicle Speed Sensor) the ABS won't work, but neither will the speedometer, or it may bounce wildly, and if you have an automatic transmission, it may not shift right.
Old Oct 15, 2012 | 04:48 PM
aduckfan's Avatar
aduckfan
Thanks for replying. Well that figures it will be a trip to the Ford dealer. The speedo works fine. Only the cruise doesn't work. All the fuses are good so I'm out of ideas.
Old Oct 15, 2012 | 04:53 PM
DIYMechanic
Have you checked all the tail lights? Check the one on the back of the cab too. Does the pedal get real hard if you press it more than once?
Old Oct 15, 2012 | 05:45 PM
aduckfan's Avatar
aduckfan
I'll check brake lights peddle pressure is normal.
Old Oct 15, 2012 | 06:01 PM
aduckfan's Avatar
aduckfan
Your right the light on the cab is out. Fun part will be changing it since I have a sung fit canopy but we'll get 'er. Thanks for the tip. Hope it works.
Old Oct 15, 2012 | 06:06 PM
DIYMechanic
There is a pretty good chance that the burned out bulb is causing your issue. I take it you already checked the brake fluid level?
Old Oct 17, 2012 | 10:33 AM
aduckfan's Avatar
aduckfan
Sorry about the delay responding. Fixing the light fixed the problem. Was an adventure getting to it but worth the effort getting cruise control back. Thanks again I don't understand the relationship but I guess it's a good idea telling me I'm either low on brake fluid or a light out. Hope this helps others.
Old Oct 17, 2012 | 01:59 PM
DIYMechanic
I'm glad that fixed it for you. The issue is that Ford uses the tail light path as a signal path for the ABS, Cruise Control and Torque Converter lockup. If there is a burned out lamp, it interrupts the signal path and causes issues with things. Kinda screwy, but that's the way they designed it to work.
At any rate, I'm glad that fixed it for you.
gasman6674
Aug 9, 2010 02:50 PM
ttttmaxx
22
Feb 16, 2009 06:29 AM
84-250
15
Jan 9, 2009 03:50 PM
Pilgrimjt
Feb 6, 2008 10:13 PM
gemac
Apr 25, 2001 11:20 AM
