need help with zf5
Old Oct 14, 2012 | 08:38 PM
brads93 idi's Avatar
brads93 idi
need help with zf5
I got around to installing my spare transmission I had but got it in with the new clutch disk that needed replaced from when I did my single mass swap now I have a problem trying to het it in gear while sitting it dose alright while driving down the road what do I need to look at
Old Oct 14, 2012 | 09:30 PM
Ford_Six's Avatar
Ford_Six
The clutch isn't releasing all the way. Is it getting full travel at the slave cylinder?
Old Oct 14, 2012 | 09:54 PM
brads93 idi
I don't think its getting full travel I just went out and tinkerd with it some more and not holding the brake and sitting on flat ground I can barely put it in gear and the truck will slightly move not much tho ...... Let me guess slave cylinder???
Old Oct 15, 2012 | 11:09 AM
brads93 idi
What's the odds of a pressure plate taking a crap with 6000 miles on it ???? And what would make a throw out bearing fall apart with the same amount of miles
Old Oct 15, 2012 | 01:30 PM
farmert's Avatar
farmert
Made in China?
Old Oct 15, 2012 | 02:04 PM
brads93 idi
Nope made in Texas by valair inc
Old Oct 15, 2012 | 02:06 PM
brads93 idi
Throw out bearing Idk .... I'm running a moog now
Old Oct 15, 2012 | 05:15 PM
bashby's Avatar
bashby
Could be air in the system, try bleeding it.
Old Oct 15, 2012 | 05:35 PM
whalebus2112's Avatar
whalebus2112
It sounds like air in the lines. Get it going in 2cd an go drive it on a bumpy road and it will beat the air out of it and give you full pedal and travel.
Old Oct 15, 2012 | 07:52 PM
Ford_Six's Avatar
Ford_Six
I have had good success with gravity bleeding the system, just open the screw on the slave a bit until fluid trickles out, take the cap off the master and keep the level topped up.
Old Oct 15, 2012 | 08:13 PM
brads93 idi
Well I blead the slave cylinder and what u know it worked I guess when I released the pressure from taking it off it drained the master but I'm gettin air from somewhere so I guess its gona be a new sc then m.c.
clunker86
1983 - 2012 Ranger & B-Series
Apr 21, 2009 01:48 AM
strokin'_tatsch
37
Jul 3, 2008 08:36 PM
Daveski
Apr 23, 2007 08:29 PM
Ranger4x4
Jan 25, 2007 07:17 PM
johnrebbb
Dec 20, 2003 02:13 PM
