I bought F250 Diesel, not 4x on 9/11. On 10/11, speedometer went to 28MPH minimum. Actual speed appeared to be reading minus 28. Next day it failed. Yesterday service engine light came on. 2006 automatic. Tried search but all seem to be 97 and older where actual cables were used. Should I look for a fuse? any ideas?
Hoping it is not the computer...
Thanks.
Only one trouble code: "P0299 Turbocharger or Supercharger "A" Underboost Condition".
I'm beginning to think the culprit for this issue is Cetane related. Have filled up twice since driving it off dealer's lot where it sat for a month. Both fillups at Walmart; and I have babied the engine the whole time. Walmart's price is 20 cents lower than anyone else around here. I wondering if their cetane rating might be 20% lower too. I read that Motorcraft Cetane Booster (something like that) is recommended at every fillup. I'm going to try truck-stop diesel+additive, then drive it hard (past 2,000 RPM). Many of the recomendations of the fault code involve cleaning parts related to EGR, EBP and other turbo related.
Of course this does not address the screwed up speedometer.
Found the TSB for instrument gauges. Removed the cluster. Have a couple of burned out bulbs. There are 14. Thought I would stop by auto parts store. No help. Bulbs are not listed in any Sylvannia reference, Clinton, or owner's manual. Someone wrote to be careful as several fit but could fry the instrument panel printed circuit board. Also see where a member is thinking of going with LED's. Going to search for an on-line bulb vendor but still don't have the Ford specs for the little lamps. Not sure I want to tackle the issue of the appliqué peeling which might have caused the speedometer failure. For now, I will dust and clean the bulbs, then put everything back. Have not jacked up the truck to inspect the sensor on the pumpkin.
Regarding the turbocharger. I don't get any black smoke, white smoke, hesitation, or lack of power at any point. In addition, the turbo gauge (psi?) appears to work properly, displaying a range of readings as truck accelerates (for instance) onto an interstate highway. A video illustrates the variable geometry turbocharger open, closed, and in the middle position. My question now is this: Does the turbo gauge reflect the variable geometry taking place? For example, does zero mean the VGT is in the closed position; and does 25psi indicate it is open?
