No Speedometer/ABS light/ Check engine Light
Old Jan 3, 2006 | 04:32 PM
JamesSandberg's Avatar
JamesSandberg
Cool No Speedometer/ABS light/ Check engine Light
The other day while I was driving to work my speedometer suddently went cazy. It would jump around and never stay in the same place. About the same time my ABS light came on and the next day my check engine light came on. I have checked all of the connections and disconnected that battery to re-set the computer with no luck. My speedometer now just sits at zero, my odometer is not working and my check engine light and ABS light are still on. Is there a connection I missed that could be loose, or does anybody have any other ideas? ANy help is gratly apprechiated. Thank you.
Old Jan 3, 2006 | 04:36 PM
butch h's Avatar
butch h
Sensor in rear axle?
Old Jan 3, 2006 | 05:58 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Perfect symptoms for a failed VSS (vehicle speed sensor, located on the top of the rear pumpkin). They cost about $20 and take 15 minutes to install.
Old Jan 4, 2006 | 08:58 AM
pawpaw's Avatar
pawpaw
I agree with Butch & Bill sure is showing all the symptoms of a faulty speed sensor.
If your in doubt, you could run this ride by your local autoparts store & have them scan the computer for codes to see if it'll confirm a faulty VSS. Most will do the computer scan at no cost, if your having trouble or the CEL is on.
As Bill pointed out, it's located atop the rear differential, held in by one 10mm bolt & clamp & is easy to change, if you like turning your own wrenches. Retorque the bolt to 25-29 ft/lbs.
Let us know what you find & do.
Old Jan 4, 2006 | 03:19 PM
JamesSandberg
I replaced the speed sensor today and all is well!!!! Thank you very much.
Old Jan 4, 2006 | 03:32 PM
pawpaw's Avatar
pawpaw
AIIRIGHT, good feedback & another satisfied customer, glad to hear your back on the road James.
iwals
Sep 9, 2015 11:57 AM
KaiserKlauss
Jun 16, 2015 06:02 PM
artguy
May 4, 2011 07:12 PM
matth2818
Jun 12, 2006 09:19 PM
