Problems with 5,8er EFI
Old Oct 14, 2012 | 04:54 AM
Commander666's Avatar
Commander666
Hi,Folks
First of all: sorry for bad english
I´m Stefan (call me Brinki) from Germany. I´ve got some problems with my new 94´ Ford Econoline. Because of not really good technical english, a friend of mine, living in NC/USA, does translations for me. Read what the problems are:
Symptoms: Rough idle, sometimes the engine even dies and also occasional misfires. Engine hesitates when throttle is increased and stumbles under partial load.
Items replaced or checked: Distributor cap and rotor, fuel and airfilter, sparkplugs and several vacuum hoses. Oxygen ratio and fuel pressure were checked and within range. Ignition timing according to manual, ignition advance works.
I am at a loss where else to look.
any help????
I´ll also would like to do an introduction, but can´t find where...
Old Oct 14, 2012 | 10:27 AM
baddad457's Avatar
baddad457
I'm no expert, but you might try replacing the throttle position sensor, it's located on the bottom side of the throttle body, so you'll need to pull the throttle body to change it. I've had to replace two of these on two different 5.8's I've owned. Also replace the fuel filter if you have not done so already.
Old Oct 14, 2012 | 12:16 PM
Conanski's Avatar
Conanski
Before replacing anything else you need to pull the codes, this can be done without any special tools by following the procedure found here..Fuel Injection Technical Library » How To Run a Self-Test or you could get a simple code reader like the Equus 3145.. Equus 3145 Ford Digital Code Reader : Amazon.com : Automotive
Old Oct 15, 2012 | 01:19 AM
Commander666
Thank you very much for response. Fine hints, so i´ll follow them and tell you, what i find out.
Old Nov 6, 2012 | 02:14 AM
Commander666
self test done
Hi,folks..
here i´m back again. Done the self test running and i´m not sure, what i´m find out.
The "check engine"-light does the following blinks:
first -we where not sure how to notice it- the blinks were like this:
6 - 3 - 6 pause 6 - 3 - 6 pause 1 - 1 - 1
the second run - we hope the system will replay the codes to get sure what we notice- the blinks were only like this:
1 - 1 - 1 pause 1 - 1 - 1
we did the KOEO-self running
therefore the codes mean: 1-1-1 system pass ( german translation??)
6-3-6 TOT sensor voltage out of self test
range ( what is TOT??)
is there any sense in this codes in connection with my described problem??
No indication to an defect throttle position sensor (TPS??)
what YOU mean?
Old Nov 6, 2012 | 09:15 AM
Conanski's Avatar
Conanski
TOT is the transmission oil temp sensor, but this may be a misleading code because the test should be performed after the powertrain is at operating temp.
But the fact that everything else is clear(111 codes) means you have no further electronic problems so the stumbling is related to potential problems like bad plug wires, broken vacuum lines, low fuel pressure, or rusted or broken smog equipment. The air injection system that routes around the back of the engine and connects to either the heads or the exhaust will produce a lean stumble if there are any leaks in it, this will show as a an exhaust leak that you can't quite pinpoint or a problem that only occurs once the engine reaches operating temp.
Old Nov 6, 2012 | 11:18 AM
Commander666
Hi,Conanski!
Thanks a lot for detailed description. Every single part of the ignition is brand new, fuel pressure at 2,5 bar, and all filters are new. Compression is even checked and nice....I´ll try to translate your further instructions and hints and will be back.
Old Nov 11, 2012 | 08:14 AM
Commander666
Here i´m back again, Translation-job is done, every part is checked up, once and twice. Can´t find any failure... Don´t know what else can be done..
By the way...can you take a look on these picture, please?
whats missing???
thanks a lot
Old Nov 11, 2012 | 02:31 PM
Cobra-Kai's Avatar
Cobra-Kai
On the pipe at the Filterbox goes an Hose to the Air Pump.
The big opening misses an Snorkel that goes above the Battery and on this snorkel is an elbow where the cut-off hose belongs
In German:
An das Rohr vom Filterkasten gehört ein Schlauch zur Luftpumpe.
Bei der großen Öffnung fehlt ein Schnorchel der über der Batterie verläuft und an diesem Schnorchel kommt ein Winkel wo der abgeschnittene Schlauch dran gehört.
Old Nov 12, 2012 | 09:02 AM
Commander666
Ja, da schau her!! Ein Landsmann !!
WAU!!!! Inklusive einer Übersetzung
in english:
WOW!!!! Including translation thanks
Something like that is what i thought. Today I put the bigger hose (Air-Pump IN) with an extension to the air-filter Clean-side, and the smaller hose aside, so that comes no dirt in it-
i think about to put a small air-filter, like these in it (Air-Pump OUT). Do you think that will be ok??
Old Nov 20, 2012 | 08:52 AM
Commander666
Hi,folks!!!
Done everything i can, no success!! Getting crazy.....
No one here with further proposals???
Old Nov 20, 2012 | 05:20 PM
dancing4raiin's Avatar
dancing4raiin
Commander, I dont have any help, but i'm following along because i'm having the same problems with my 5.0 V8 EFI engine
Old Nov 21, 2012 | 08:53 PM
dancing4raiin
Commander not sure if this will help you, but im going to do this with my engine
gdudik
15
Mar 25, 2020 07:31 PM
hivoltj
41
May 19, 2019 11:31 AM
justroll
Apr 28, 2019 06:33 PM
imrickyurnot
2004 - 2008 F150
Jun 8, 2017 01:08 AM
landyaght
Oct 28, 2013 05:45 PM
