1978 - 1996 Big Bronco
vacuum lines
Old May 19, 2003 | 11:27 AM
perryphilip's Avatar
perryphilip
vacuum lines
I am trying to remove all the emmisions components (EGR, air injection) and related vacuum lines from my 5.8HO. The only vacuum lines i would like too keep are the ones to the heater controls, the throttle kicker, the ignition module, the distributor, cruise control, and brake booster. Does any body have any suggestions for doing this?
Old May 20, 2003 | 01:38 AM
ryanguglich's Avatar
ryanguglich
vacuum lines
sounds like you have it all figured out already. I would just take the main vac. tree in the rear of the manifold and route the large one to the brakes. I would run a wax. temp vac switch inline to the distributor advance. and run a main one to the cruise and tee it off to run the heater controls.
Old May 20, 2003 | 06:16 AM
perryphilip
vacuum lines
why do i need a wax. temp vac switch? There isnt one inline with the distributor now
Old May 20, 2003 | 08:33 AM
broncoholic's Avatar
broncoholic
vacuum lines
If I may ask, what is a wax temp vac switch?
Old May 20, 2003 | 08:37 AM
perryphilip
vacuum lines
yeah, what is it, and why do i need it?
Also, what vacuum lines do i need to keep to retain the throttle kicker so my idle bumps up when i turn the a/c on?
Old May 20, 2003 | 02:16 PM
ryanguglich
vacuum lines
I don't KNow about the AC. I imagine it's a line from the ac control to the idle - up solonoid (I've seen electric ones that work well though)
The wax switch was on the 351 i pulled out of a car I thought it's a great idea to make starting and cold running easier.. It won't advance the timing until the engine reaches op.temp.
Juniorssrollin
1997 - 2003 F150
Aug 4, 2015 08:40 PM
rangerbud
May 20, 2015 09:06 AM
Dschonauer
Mar 11, 2015 09:53 AM
tjc transport
Oct 23, 2013 12:14 PM
dyoungen
Jan 19, 2012 09:39 AM
