Sponsored by: Real Truck
Strange "feel" when taking off....
Old Oct 13, 2012 | 09:15 AM
NTENSE's Avatar
NTENSE
I have an 03 F250 4WD CC 7.3 with 164k miles and whenever I take off from a light, or come to a stop that causes the body to shift foward or back, I can feel a "metal on metal" or "something needs to be greased" feel but I cant find what it is. The drive train is tight. No noise going in and out of drive or reverse from park, just when leaving from a dead stop or coming up to a light or stop sign. It does go away, however, when i have a trailer in town and is non existant while going down the road. I have noticed that the slide shaft boot is missing the front band. Could greasing the splines be the problem or solution?
Thanks,
Chris
Old Oct 13, 2012 | 09:46 AM
droldsmorland's Avatar
droldsmorland
Do a search on my user name or check the tech section here. I think your experiencing the standard driveline thunk. It’s a simple fix if this is the actual problem. You should probably get a new boot kit which will come with the Oetiker clamps. Only problem is you will need to find a way to crimp the clamps or purchase the Oetiker clamp pliers. You cant use side cutters to crimp them. The boot kit is ~$40, the Ford Teflon grease is $10 (it’s the only grease that works) the pliers are $40 unless you can find cheaper non-chinese knock offs?<O</O
Old Oct 13, 2012 | 09:55 AM
Snowseeker's Avatar
Snowseeker
My buddy had a driveline "thunk/weird feeling" while leaving stop signs in his 02 7.3 as well. His limited slip clutch packs were completely worn out and slopping around.
Old Oct 13, 2012 | 09:58 AM
NTENSE's Avatar
NTENSE
Drivline thunk is the same fix as greasing the splined shaft behind the carrier bearing on the drive shaft?
Hope it's not limited slip issues.
Old Oct 13, 2012 | 10:49 AM
P.Bronner's Avatar
P.Bronner
I'd bet you a nice cold beer that its the slip yoke splines sticking as described above. Its a common issue, and the band clamp missing is going to be a big contributing factor due to grease getting out and crud getting in. Limited slip clutch problems are going to manifest when cornering.
Old Oct 13, 2012 | 11:52 AM
NTENSE's Avatar
NTENSE
I'm gonna grease the splines first thing in the morning and put a new clamp on the boot. It seems like an easy fix and it sounds like it needs to be done for routine maintenance anyhow.
Thanks.
Old Oct 13, 2012 | 01:19 PM
Fordfanatic4life's Avatar
Fordfanatic4life
its the dry slip joint..
Old Oct 13, 2012 | 01:38 PM
NTENSE's Avatar
NTENSE
Good deal,
Thanks
Old Oct 15, 2012 | 09:28 AM
NTENSE's Avatar
NTENSE
Thanks to all for your help. It was the slip joint. When I pulled it apart yesterday, the splines were bone dry but all the blue teflon type stuff was all still intact. None of it had worn off at all. I'm thinking that's a good thing. So I filled it back full of grease, replaced the front boot clamp, and now I have no more problems.
Thanks again,
Chris
Old Oct 16, 2012 | 06:40 PM
Fordfanatic4life
gotta love the simple fix's
Old Oct 16, 2012 | 08:06 PM
Lattitude Adjuster's Avatar
Lattitude Adjuster
If you are careful with the right size flat screw driver you can save the clamp.
You will need a pair of end nippers to re-crimp the Oetiker clamps.
By the way you only need to remove the front clamp.
Old Oct 18, 2012 | 09:38 AM
NTENSE's Avatar
NTENSE
I used a generic CV clamp from the parts store. It seems to be doing well.
Simple fixes make life better .
Old Oct 18, 2012 | 11:02 AM
Pickupmanx2's Avatar
Pickupmanx2
Hmmmm,,, gonna have to try that on my 02 F350 4x4/DRW/CC it has a "thunk" on take off,,,
DRM2004
2004 - 2008 F150
28
Feb 21, 2013 01:34 PM
bbender85
May 4, 2012 10:42 PM
H.T. Mills
Sep 16, 2010 08:08 PM
pfish
Apr 22, 2009 12:45 PM
carpscrib
Dec 5, 2007 07:27 AM
