ZF5 Reverse Problems & Indicator Questions
Old Oct 12, 2012 | 09:59 PM
Gary Lewis's Avatar
Gary Lewis
My ZF5 is kinda tough to get fully into reverse. Maybe I don't have the feel of it yet, or maybe it'll get better when I change to Royal Purple Synchromax, but maybe not. Usually I get it in fine, but some times it apparently isn't quite all the way in and the gears grind.
So, I'm thinking about utilizing the backup light switch on the ZF to put a REVERSE warning light on the dash in the far left position that is currently unused. Hopefully that would let me know when I'm not in so I could try again.
That brings me to several questions:
  • Does anyone else have problems getting their ZF fully into reverse?
  • Is there a known problem with reverse on the ZF that would suggest I have trouble looming?
  • What do you think about the idea of having an indicator on the dash?
  • The backup light connection on the ZF doesn't look like anything from one of these trucks. Anyone have one of the connectors? Or, is there a source for them like HELP?
  • To use the far left indicator position I'll have to do it like the 4x4 indicator on the right, meaning a separate bulb/socket combo that twists in. Anyone know of a source for those, like HELP?
Old Oct 12, 2012 | 10:10 PM
Fordzilla80's Avatar
Fordzilla80
Remember that you'll have to have a source of power for that light. The 4x4 socket plugs into both the transfer case, and the fuse panel.
Old Oct 12, 2012 | 10:11 PM
Diesel_Brad's Avatar
Diesel_Brad
Synchronizer is bad. I bet 1st is a lil hard too.
If it pops out of gear, then you have bad bearings or a chipped tooth
Old Oct 12, 2012 | 10:19 PM
Gary Lewis's Avatar
Gary Lewis
Yep, just like the 4x4. That's why I need a socket just like that one.
I haven't noticed it popping out of gear. As for 1st, I dunno - I rarely use it. But, on the few times I have I haven't noticed it being hard. Is there a connection between 1st and reverse synchros?
Anyway, a good reason to go to RP as it is far less expensive than an overhaul.
Old Oct 12, 2012 | 10:33 PM
Diesel_Brad
The oil is not going to help when the truck is not moving.
Typically 1st and reverse get worn equally sense they are your 2 maneuvering gears
Old Oct 12, 2012 | 10:36 PM
Gary Lewis's Avatar
Gary Lewis
Makes sense - about 1st & reverse as well as sitting still. Don't like it, but thanks.
Old Oct 13, 2012 | 10:39 AM
dustybumpers's Avatar
dustybumpers
Make sure the brake fluid is topped off in the clutch master.
I had to change mine in my 89, it had so much dirt in it, the holes in the bottom of it were plugged, going into reverse was sometimes next to impossible
Old Oct 13, 2012 | 10:48 AM
Gary Lewis's Avatar
Gary Lewis
Thanks, but you might have missed that this is mechanical linkage. And, while I'm now rethinking the decision to go that way, I've now rebuilt the entire linkage with the exception of the rubber cover on the clutch pedal so want to continue on this way. And, I know some of the guys wanting to install a ZF5 are still using mechanical linkage so wanted to sort out all the problems I could in that setup. But, were I to do it over again....
Old Oct 13, 2012 | 11:02 AM
dustybumpers
Yeah, but the hydro has it's own set of issues too, mine has "eaten" the spring 3 times. Nothing is fool proof
Old Oct 13, 2012 | 11:05 AM
Gary Lewis's Avatar
Gary Lewis
True. In some ways better the devil you know that one you don't know. At least this won't crack the firewall.
Jacob90
Mar 24, 2017 10:25 AM
deljac
Dec 8, 2012 12:25 PM
mech1
Jan 20, 2011 04:56 AM
SgtJoe
Aerostar
May 24, 2004 03:27 PM
soupy264
Feb 19, 2001 09:13 PM
