Which rear end?
Old Oct 12, 2012 | 08:54 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Which rear end?
My 51 F4 is stock. The Shop Manual says the two rear axles available for the F4 are 8T-4209C with 5.14 gear ratio OR 8T4209B with 5.83 gear ratio.
The number stamped into the axle housing is 1133. The Illustrations Parts Catalog shows the 48-52 TL uses a Timken 51524.The Parts Text Catalog shows this is a Ford rear axle.
Here's the stamp. Does anyone know what this rear axle is and is there a reference for the gear ratio?
Old Oct 12, 2012 | 10:22 PM
Jolly Roger Joe
I think I'll have to jack up the rear end, mark the drive shaft, and rotate a wheel through one full turn counting the turns on the drive shaft. That will tell me the ratio won't it? 10.25 turns for the 5.14 and about 11 2/3 turns for the 5.83.
Will that work?
EDIT: I did this division incorrectly,,, see below
Old Oct 12, 2012 | 10:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, if you only jack up one wheel (and have the trans in neutral). Personally, I prefer to jack up both wheels and turn the pinion to get one full wheel rotation, but I don't have a big F-4.
Old Oct 12, 2012 | 11:37 PM
Jolly Roger Joe
Thanks Ross. Maybe I'll get that done this weekend and solve my mystery of the rear end gear ratio.
Old Oct 14, 2012 | 09:37 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Joe - can't help with the case stamping code, and sounds like you and Ross have the method for figuring out the ratio, but I think you've been victimized by the confusing info in the 1964 reprint chassis catalog. The Timken 51524 axle was used in the F-2, F-3, and P.D. models (D, Y, and J), (and was also used in the earlier tonner model), but not in the F-4 (Model TL). The book you're looking at shows the 51524 diagram as typical for the single speed Timken, but it's wrong that that axle was used in an F-4. The text section shows that the 48-50 TLs used Timken model 53566, then switched to some ill described "Ford" axle in '51 and '52. But if you go back to the original Jan. '52 edition or Jan. '54 edition of the chassis catalog it's shown that the Timken 53566 was used for the whole F-4 model run '48 to '52. Same part numbers for the case halves for all years. Just an FYI. Stu
Old Oct 14, 2012 | 11:19 AM
Jolly Roger Joe
Thanks Stu.
It is rather confusing to have so many different descriptions "in writing" in official (looking) Ford documentation. Thanks for clarifying that for me. I wrote it down...
Old Oct 14, 2012 | 12:48 PM
52 Merc's Avatar
52 Merc
Confusion arising from reading Ford parts catalogs is usually self inflicted. It's important to remember that these catalogs are not assembly manuals. They are simply a listing of interchangeable, replacement parts available from Ford at the time of printing. The more time that passes between the assembly of the subject vehicle and the printing of the catalog, the greater the chance the information is unreliable for determining OEM installed equipment, as replacement parts often become whatever is on the shelf that will work to keep a vehicle on the road. It's a common misconception among a lot of people to believe the parts catalog is gospel for original assembly details.
Old Oct 14, 2012 | 05:34 PM
Jolly Roger Joe
Is this right?
I jacked up one side of the rear end, marked the drive shaft and the wheel, and rotated the tire through one full turn. The drive shaft rotated slightly more than 2 1/2 turns. So I'm guessing my earlier formula is totally wrong, and I need to multiply the number of drive shaft turns by 2 to get the correct number.
5.14 / 2 = 2.57, so I guess my rear axle is a 5.14.
5.83 / 2 = 2.915 and the drive shaft was nowhere near 3 full turns.
I can still pull stumps in granny 1st, but at least maybe I'll be able to do 50 mph.
knuckledragger66
Mar 31, 2012 08:17 AM
4x4fordtrkn
Aug 16, 2005 05:06 PM
Jacques
Jul 21, 2004 07:52 AM
millwood1
Dec 16, 2003 06:29 PM
Ripman
1997 - 2003 F150
Oct 3, 2001 10:26 PM
