Edge and scanguage2
Old Oct 12, 2012 | 03:21 PM
run6.0run's Avatar
run6.0run
Edge and scanguage2
Is anyone running the scanguage, with the edge module that plugs into the computer on the driver firewall? My edge has to be unhooked in order for ids, or ae, or a hyperpac (all obdII plugs), to be able to read. My edge works for me, for now, just would like the scanguage and the edge (that would be 8 gauges). Wondering if anyone is running the scanguage, along with the edge? Does both of them function properly at the same time?
Old Oct 12, 2012 | 04:06 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
DashBoss and Torque run multiple gauges at once. DashBoss has a 12 gauge screen plus an additional 3 screens of 4 gauges for 24 programmed gauges.
Just a thought.
Josh
Old Oct 12, 2012 | 05:23 PM
Crash16's Avatar
Crash16
Does someone make an obd2 splitter? That would work for ya.
Old Oct 12, 2012 | 06:23 PM
Crash16's Avatar
Crash16
Old Oct 12, 2012 | 06:54 PM
run6.0run's Avatar
run6.0run
My edge doesn't plug into obd2. But it doesn't let my ae or ids communicate
Old Oct 12, 2012 | 07:12 PM
Rusty Axlerod's Avatar
Rusty Axlerod
There is such a thing but certain devices don't play well with each other.
Old Oct 13, 2012 | 03:11 PM
run6.0run's Avatar
run6.0run
Bump, has no one tried the scan guage with the edge that plugs in under the hood?
Old Oct 13, 2012 | 03:51 PM
holdtyte's Avatar
holdtyte
I have the edge juice with attitude display module as well as the scanguage 2. I've had the edge since the truck was new (07) and the scan guage for a couple of months. Haven't had any issues. They both do their jobs well.
Old Oct 13, 2012 | 04:54 PM
run6.0run's Avatar
run6.0run
Where does your edge plug in, holdtyte??? Is it the juice platinum? Mine is the old style with the screen on the display that has the 4 buttons on the left. No touch screen on mine. This would be great.
Old Oct 13, 2012 | 05:27 PM
holdtyte's Avatar
holdtyte
yes, it's a platinum. My display is an 07 so it has the 4 buttons on the left also. My juice module is hooked up in series to the ECM. The connections are between the drivers side battery and the fender. There is another sensor that it ties into also. can't recall the name off the top of my head tho.I have sent my module into edge twice now to get the newest flash's. They are awesome to deal with.
Old Oct 13, 2012 | 05:56 PM
run6.0run's Avatar
run6.0run
That's very cool. So now I know I can get the scanguage n use both. I've talked to edge a couple times, they also have a trade in program. I think it's half price on new. I've never had mine flashed. It's seriously got right at a million miles on it.
Old Oct 13, 2012 | 06:01 PM
holdtyte's Avatar
holdtyte
I thought 240 000 on my '07 was alot! At one million miles do u ever turn it off?
Old Oct 13, 2012 | 07:04 PM
run6.0run's Avatar
run6.0run
Two different trucks. Both 06's. I've had it since late 06. Oh, actually, I bought it used off eBay then for 500. I think I got my $'s worth
Old Oct 13, 2012 | 07:29 PM
Fulthrotl's Avatar
Fulthrotl
OBDII Signal Splitter Y Cable, J1962M to 2-J1962F, 1ft
$20
Old Oct 13, 2012 | 08:35 PM
Lilpooh's Avatar
Lilpooh
Originally Posted by Fulthrotl
The plug is no problem; there are even some nice "Y" cables out there already for about $20 from China.
However, the problem stems from the way things are registered on the CAN bus. When plugged into the OBDII port, you have to use a certain address. I.E. there's a reserved "slot" for you to talk to the other modules on the bus. So if there's somebody already on there using that slot, somebody else can't also use that "slot" at the same time.
hi-jacker
Jul 24, 2009 11:31 AM
43Duc
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Feb 18, 2008 12:58 AM
fordboy2
Dec 1, 2007 12:49 AM
